dx dizzy work on z6?
Old Jan 16, 2008 | 09:05 PM
thesoundofturbo's Avatar
Default dx dizzy work on z6?
was wondering if my dx dizzy would work or my z6
its in a 95 ex coupe.my z6 went dizzy went out and i wondered i i could use a dx dizzy for now untiolle i get the z6 one.i wanted make sure first before i tried it\\
Old Jan 16, 2008 | 10:22 PM
saywhat's Avatar
Default Re: dx dizzy work on z6? (thesoundofturbo)
I think all the SOHC distributors are interchangeable as long as they are the same OBD generation.
Old Jan 16, 2008 | 10:23 PM
Syndacate's Avatar
Default Re: dx dizzy work on z6? (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">I think all the SOHC distributors are interchangeable as long as they are the same OBD generation.</TD></TR></TABLE>
All the dizzies are the same except OBD-I, OBD-II, and OBD-IIB all had different plugs on the end to which the harness plugs in (which can be done quickly, cheaply).
BUT
You're still **** outta luck, as the only one that wasn't the same (physically, not the wires) as the every other is the OBD-I VTEC (D15Z1, D16Z6, and D15B). It won't work. The OBD-I VTEC used different distributor bolt patterns.
Old Jan 16, 2008 | 10:32 PM
salturbo's Avatar
good luck with that one bro
Old Jan 16, 2008 | 10:51 PM
ddd4114's Avatar
Default Re: (salturbo)
It'll work if you like filing...
Old Jan 16, 2008 | 11:07 PM
court's Avatar
25 Year Member
Default Re: (ddd4114)
just change the internals out
Old Jan 17, 2008 | 04:59 AM
92ehatch's Avatar
Default Re: (court)
i had a dx dizzy on my z6 and it wouldnt reach the correct timing.
had it advanced all the way and it was still short.
put a z6 on it and it did fine.
so no, they wont work unless you file the holes on the dizzy a little longer
Old Jan 17, 2008 | 07:20 AM
Default Re: (92ehatch)
alright thanks for your help guys
i just cant seem to find anyone around thats selling a z6 dizzy
Old Jan 17, 2008 | 09:29 AM
saywhat's Avatar
Default Re: (court)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">just change the internals out</TD></TR></TABLE>
Just do this, I have done it a few times.
Old Jan 17, 2008 | 09:35 AM
bpkmrtoes's Avatar
Default Re: (saywhat)
i do this all the time. even between sohc internals and bseries internals. everything inside is either phillip screws or female connectors.
ef9wpb
Oct 10, 2007 06:22 AM
dohdoh420
Oct 30, 2005 05:54 PM
91tegrals
Apr 5, 2005 02:01 PM
91tegrals
Mar 11, 2005 07:18 AM
egizzle8
Feb 9, 2004 07:25 AM
