Suspension & Brakes Theory, alignment, spring rates....
Wheel bearing grease ok for short shifter? or is there better stuff?
Old Jan 15, 2008 | 09:09 PM
aleks77's Avatar
Default Wheel bearing grease ok for short shifter? or is there better stuff?
Just doin my 5spd swap and i got a short shifter, i noticed there is grease at the bottom of the old oem stick where it connects to the linkage? its black, i went to a local auto parts store and they gave me red wheel bearing grease, just wondering if this is fine? or is there some better stuff i can use, the smoother the shifts the better, altho i know that also depends on the tranny itsself.
Thanks!
Old Jan 16, 2008 | 09:26 AM
Targa250R's Avatar
be professional
Default Re: Wheel bearing grease ok for short shifter? or is there better stuff? (aleks77)
Regular multi-purpose/wheel bearing grease is fine for the linkage eye joint.
I use white lithium grease for the pivot ball.
Old Jan 16, 2008 | 10:24 PM
aleks77's Avatar
ah sorry i dont know the terminology, which is the eye joint, and which is the pivot ball?
thanks :D
Old Jan 17, 2008 | 11:20 AM
Targa250R's Avatar
be professional
Default Re: (aleks77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">ah sorry i dont know the terminology, which is the eye joint, and which is the pivot ball?
thanks :D</TD></TR></TABLE>
It's not exactly the "correct" terminology (I made it up), but to make things easier to understand, I call the hole where the linkage bolts up the "linkage eye," and the bulbous section in the middle of the shifter the "pivot ball."
cmross13
Transmission & Drivetrain
Jan 25, 2010 07:05 PM
philosofy1
Aug 10, 2006 12:44 PM
snouka
May 5, 2006 11:22 AM
TylerB
Apr 28, 2004 07:18 PM
