custom short shifter
Old Apr 28, 2004 | 07:00 PM
TylerB's Avatar
Default custom short shifter
So, I pulled my motor today and thought I might as well start on my shifter. Now, I've been told that if you want to shorten your shift, you need to lengthen the metal between the bearing and the ball. But, I've also been told that you just cut and weld the ball to the bearing. Which is true? And also, is there a possiblility that i cut/lengthen too much?
Old Apr 28, 2004 | 07:18 PM
Dov's Avatar
Dov
Default Re: custom short shifter (H22 VTEC)
Why try to re-invent the wheel. There are tons of manufacturers that make short shifters and they a cheap too. All the time and effort it takes to build your own you could go to the local shop and buy one cheaper!!!
hectic57
Feb 27, 2008 08:16 PM
AVXHATCH
Feb 27, 2003 02:26 PM
crewjones
Sep 27, 2002 08:40 PM
ngkplugs
Aug 24, 2002 05:07 PM
