code 45
Old Jan 15, 2008 | 01:52 PM
whiteciv88's Avatar
Default code 45
ok so first i will tell you my story i had fixed this a couple of months ago. o2 sensors and such. i have been running the same set up for months now. so here it is i have ebay headers going into a stock cat and now it is throwing code 45 looked at all the bolts tight as a button and even took off the neg battery terminal. so what do you think it could be??
get back to me soon i hate yellow lights
Old Jan 15, 2008 | 02:09 PM
saywhat's Avatar
Default Re: code 45 (whiteciv88)
What year/OBD is your Civic?
Old Jan 15, 2008 | 04:12 PM
whiteciv88's Avatar
Default Re: code 45 (saywhat)
oh yeah sorry about that its a 2000 ex obdII
Old Jan 15, 2008 | 05:11 PM
whiteciv88's Avatar
ttt
Old Jan 16, 2008 | 01:58 PM
saywhat's Avatar
Do you have anything modified as far as the fuel delivery system?
Old Jan 16, 2008 | 02:03 PM
saywhat's Avatar
Try running a different octane gas, check the gap on your plugs, make sure your injectors are all measuring the correct amount of resistance, make sure your air filter is clean, not obstructed. You aren't running a VTEC hack or anything like that are you?
EDIT: did you replace both O2 sensors?
DJ Gurgla GSR
May 30, 2006 12:50 PM
brnyrdcmndo
Jun 1, 2005 06:37 PM
ActiveAero
Sep 13, 2002 08:31 PM
JSpecwest
Aug 7, 2001 10:00 AM
