Code 45 system too lean or rich?
Old Sep 13, 2002 | 03:05 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Code 45 system too lean or rich?
Ok how the heck am I supposed to check this. I figured that it was throwing a code because I don't have a cat, but I guess not after checking it today. I just changed my plugs because I figured they were fouled out and they were. They were soaked black (from running rich I guess). Now how am I supposed to lean it out or for that matter check it?
Old Sep 13, 2002 | 03:50 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Code 45 system too lean or rich? (ActiveAero Ninja Edition)
Please I need to know. This is the only time I'll bump it mods. Please don't hurt me.
Old Sep 13, 2002 | 06:28 PM
gamby's Avatar
Complete list of mods?
Do you have cam gears w/ a lot of overlap dialed into them?
Do you have a V-AFC that has been used for major changes in the fuel curve??
Either of these can throw that code. I'd think things would be running leaner without the cat, but maybe I'm wrong. If the plugs are fouled, lean it out.
A dyno with a wideband 02 ssetup could tell you the exact cause of your fuel woes.
Good luck. I'm still stuck with the same damn code, too
Old Sep 13, 2002 | 06:32 PM
92TypeR's Avatar
FSAE
Default Re: Code 45 system too lean or rich? (gamby)
I was always under the assumption that with a code 1 (O2 sensor) you are running rich. I assume this because running rich is "safer" than running lean, and the car would rather sacrafice temporary fuel economy than your motor...I could be wrong.
Old Sep 13, 2002 | 08:31 PM
Frosty_spl's Avatar
I'm bone stock except for the intake and no cat. I run open header sometimes if that makes a difference.
This is ActiveAero under another computer. My bad.
[Modified by Frosty_SPL, 9:32 PM 9/13/2002]
boosted k20
Sep 11, 2004 07:32 PM
B00ST2nR
Oct 19, 2002 01:30 PM
JM Performance
Dec 19, 2001 07:07 PM
JSpecwest
Aug 7, 2001 10:00 AM
