CaR wOnt sTART!!! HELP
Old Jan 15, 2008 | 09:52 AM
JDM_CRX_PLEASE's Avatar
Default CaR wOnt sTART!!! HELP
hello. i was workin on my car and i forgot the battry was in and when i was tightin the nut that holds i think the negative on the alternator and my wrecnch touched the fuel rail and i saw a spark now my car dosnt even turn on... what should i do???? thanks!
Old Jan 15, 2008 | 09:54 AM
1stgenboost's Avatar
check the ignition fuse.
Old Jan 15, 2008 | 09:55 AM
Default Re: (1stgenboost)
where is it located?
Old Jan 15, 2008 | 11:22 AM
lalo's Avatar
Default Re: (JDM_CRX_PLEASE)
bumppppppppppppppppppppppppppppppppppppppppppppppp ppppppppppp
Old Jan 15, 2008 | 11:52 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: (lalo)
check you batt. fuse its locate it that black fuse box by the passenger side.
thath could be it.
if it's a EG its big held with two screws. and its greet i think.
hope this helps.
Old Jan 15, 2008 | 12:10 PM
blwn95civic's Avatar
Default Re: (Dead CIVIC)
also check all fuses under the dash, there's no telling what could have shorted out and just a simple fuse can cause problems
Old Jan 15, 2008 | 12:23 PM
hmm so i would need a fuse checkr.. so the car dosnt turn on at all. as if the battery is dead..
Old Jan 15, 2008 | 01:48 PM
can you hear the fuel pump turn on when the ignition is turned to the on position?
Old Jan 15, 2008 | 02:37 PM
no the whole car dosnt even turn on like there is no power
Old Jan 15, 2008 | 02:58 PM
A-'s Avatar
A-
check main relay? buy a brand new one and tay it out.. thats what it could be,
Old Jan 15, 2008 | 03:25 PM
skateboard_ej8's Avatar
im hench irl
Default Re: CaR wOnt sTART!!! HELP (JDM_CRX_PLEASE)
you must have shorted something out. Double check your fuses.
Old Jan 15, 2008 | 03:36 PM
okay it was the batterie fuse 80A i replaced it. now everything turns on fuel pump primes. but now it only cranks and dosnt start up.. what could it be!?
Old Jan 15, 2008 | 03:42 PM
check to make sure your getting spark from the distributor. my bet is there's another fuse blown somewhere
Old Jan 15, 2008 | 03:43 PM
auto addict's Avatar
Old Jan 15, 2008 | 03:44 PM
howdo u check for a spark off the dizzy??
Old Jan 15, 2008 | 04:15 PM
A-'s Avatar
A-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">howdo u check for a spark off the dizzy??</TD></TR></TABLE>
pull a spark plug out of the head.. put in on the end of the spark plug wire. and hold it in the air and look for a spark.
Old Jan 15, 2008 | 04:22 PM
while cranking the car??
Old Jan 15, 2008 | 04:33 PM
crx_bob's Avatar
Yip, while cranking the car
A-'s Avatar
A-
yes. if u have spark u will see it at the end of the plug
Old Jan 15, 2008 | 05:36 PM
got it started!! it was the ignition fuse it was in the wrong spot so i put back in its respective numbr 9 spot :D
Old Jan 15, 2008 | 06:12 PM
A-'s Avatar
A-
good job
Old Jan 16, 2008 | 02:21 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: (A-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">okay it was the batterie fuse 80A i replaced it. now everything turns on fuel pump primes. but now it only cranks and dosnt start up.. what could it be!?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">check you batt. fuse its locate it that black fuse box by the passenger side.
thath could be it.
hope this helps.</TD></TR></TABLE>
haha i knew it was that i was stumped over that once. i felt dumb because it is so easy to see it is bad.lol
#1 Dominican
Dec 27, 2008 12:50 PM
LudeNsoL
Nov 19, 2007 08:55 AM
si90rex
Jun 24, 2007 05:53 PM
Si_Element
Sep 6, 2006 12:10 PM
Tad
16
Aug 4, 2005 03:56 PM
