89 honda civic si hatch check engine light
out of nower evrytime im driving i get check engine light..but wen i turn it off then turn it back on ..the check engine light is gone..anyone noe wats da problem???
Have you checked the code when the light is on? It would help if you can get us the code.
If you don't know how to, your ECU is under the carpet in the passenger footwell. There is a red LED on it that will blink when you have a CEL. One short blink=1, long=10. (Ex: 2 short = code 2, 3 short + 1 long = 13, etc.). There will be pauses in between individual codes. Get the code and report back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Have you checked the code when the light is on? It would help if you can get us the code.
If you don't know how to, your ECU is under the carpet in the passenger footwell. There is a red LED on it that will blink when you have a CEL. One short blink=1, long=10. (Ex: 2 short = code 2, 3 short + 1 long = 13, etc.). There will be pauses in between individual codes. Get the code and report back. </TD></TR></TABLE>
Heres the list
http://www.hondacivicforum.com/m_45386/tm.htm
Heres the list
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 »</TD></TR><TR><TD CLASS="quote">???</TD></TR></TABLE>
p28 is an obd-1 ecu. you should use a jumper in the same way the 92-95 civics do to check your codes. the codes will then blink on your dash in the form of the check engine light.
good luck.
how-to and code list:
https://honda-tech.com/zerothread/1901557
good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 »</TD></TR><TR><TD CLASS="quote">how you do dat jumper thingy???</TD></TR></TABLE>
Dude, it says how to in the link posted above.
Delano5050
Aug 5, 2008 09:12 AM
r.f.b
Dec 18, 2006 05:59 PM
shabasoft
Aug 26, 2004 01:01 PM
