EF Sedan- Are there any known problems with water leakage into the cabin?
Old Jan 14, 2008 | 07:25 PM
cx-k's Avatar
Default EF Sedan- Are there any known problems with water leakage into the cabin?
I know with DA Integras there are a few grommets that are known to dry rot and allow water into the cabin. I was wondering if anyone knows of similar problems with EF's. Ive got a musty smell in my 91 LX, and its bugging the **** out of me. I searched (skimmed) but didnt find anything. Any help is appreciated!!!
Old Jan 14, 2008 | 07:28 PM
Fuzzy Rhubarb's Avatar
Default Re: EF Sedan- Are there any known problems with water leakage into the cabin? (cx-k)
ha, leaking in EFs...
my door trim used to leak until i got it fixed. i had a musty smell, but it went away after i fixed the seals. water was getting onto the seats and really smelling it up.
Old Jan 14, 2008 | 08:24 PM
twiztid17thninja's Avatar
Default Re: EF Sedan- Are there any known problems with water leakage into the cabin? (Fuzzy Rhubarb)
could be anything my windscreen seal leaks and i need to fix that after i get it running again listen for whistling while you are driving look all around for wet spots good luck
Old Jan 15, 2008 | 04:59 AM
cx-k's Avatar
Default Re: EF Sedan- Are there any known problems with water leakage into the cabin? (twiztid17thninja)
yeah, the windscreen problem shouldnt be one, as it has a new windshield in it. I'm wondering if water is somehow making its way in through the blower motor intake. Anybody else have any input?
Old Jan 15, 2008 | 05:58 AM
mario_pic's Avatar
o **** dude that sounds like mold take ur head liner off and see if its molding if so get it replaced because mold is not good for ur health
Old Jan 15, 2008 | 06:11 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: EF Sedan- Are there any known problems with water leakage into the cabin? (mario_pic)
I've had no problems with my sedan.
Old Jan 15, 2008 | 06:46 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic &raquo;</TD></TR><TR><TD CLASS="quote">o **** dude that sounds like mold </TD></TR></TABLE>
What does mold sound like?
Old Jan 15, 2008 | 07:31 AM
nfereorhatch's Avatar
Default Re: EF Sedan- Are there any known problems with water leakage into the cabin? (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">
What does mold sound like?</TD></TR></TABLE>
i would like to know as well!
Old Jan 16, 2008 | 05:04 AM
cx-k's Avatar
Default Re: EF Sedan- Are there any known problems with water leakage into the cabin? (nfereorhatch)
haha, i guess no one has any input?
Old Jan 16, 2008 | 10:01 AM
barely4dr's Avatar
I have the same problem. I suspect it might be my passenger door weather stripping or my windscreen molding [glass shop did a shoddy install]
-Bump for answers
Old Jan 16, 2008 | 11:55 AM
akandok's Avatar
do you have a sunroof? If you do then it could be that the drain tubes are clogged
Old Jan 16, 2008 | 01:46 PM
bagpipe goatee's Avatar
All four 88-91's I've had leaked around the windshield due to being poorly installed. When cutting out the old one, installers have a tendency to scratch the frame, and then rust starts. Check in the two corners at the top, under the trim piece.
Here's a severe example:
Old Jan 25, 2008 | 09:37 AM
barely4dr's Avatar
Default Re: (bagpipe goatee)
I hope mine doesn't look like ^^that
cjw_89
14
Oct 6, 2010 12:01 PM
TigerLy
Apr 29, 2008 05:32 PM
Blk-dc2
Dec 8, 2006 10:24 PM
pinoyboiwonder
14
Nov 11, 2006 06:00 PM
