200whp possible??
95 Honda Civic Ex
D16z6 Stock
Header
Intake
Exhaust
Fuel pressure regulator
Walbro Fuel pump
330 injectors
75 shot of nitrous
stage 3 clutch
7 pound flywheel
tell me what ya think of the setup..
D16z6 Stock
Header
Intake
Exhaust
Walbro Fuel pump
330 injectors
75 shot of nitrous
stage 3 clutch
7 pound flywheel
no, with that setup you will be about 80whp away if not more........
If you want that much from a z6 I suggest installing a turbo and getting it tuned
BTW bench racing/building is retarded
you need to expiriment and learn for yourself
It might not make 200whp, but it'll still add some zip for a relatively low amount of money. If you want power that doesn't require a fill-up, look into a cheap turbo setup. I'd much rather spend more initially for a little turbo setup than a nitrous setup.
at least you're not like the other post with a d15bwhatever 60hp ef engine.
but seriously, you know the parts, you knew the answer before you posted, so why bother?
and what will happen when you hit 200whp?
Ya you might possibly get close with the NOS, But then your gona want to consider a new engine. NOS will expletive your day up....... Kinda like coming home and finding your house filled with ****.
whaaaaaaaaaaaaaaaaaaaaaaat OKAY I'm pretty sure we have the same definition as stock here right? That is nuts! Props!
So that's like a 145bhp-ish d16z6 with stock intake, stock exhaust, stock everything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rok_Stok »</TD></TR><TR><TD CLASS="quote">whaaaaaaaaaaaaaaaaaaaaaaat OKAY I'm pretty sure we have the same definition as stock here right? That is nuts! Props!
So that's like a 145bhp-ish d16z6 with stock intake, stock exhaust, stock everything?</TD></TR></TABLE>
stock as it can get. z6 trans with factory steelies. CX exhaust with a fart can.
Mr.Teal is his screen name still I think....he is from bamburg, sc. Have not talked to him a couple years now.....need to get in touch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rok_Stok »</TD></TR><TR><TD CLASS="quote">That's insane, I didn't know there was such thing as a factory freak like that.
Question: Can you really do a 60' on a bicycle in 1.6 seconds?</TD></TR></TABLE>
the answer is yes, which is why I race pro
I won the holeshot shootout in Columbus Ohio the end of last month.
I can only do it with aid of a starting gate.
here are some vids
http://www.youtube.com/watch?v=giWOxJiFmjk
here is the class I race
http://www.youtube.com/watch?v...lated
Modified by DirtySol at 1:59 AM 1/15/2008
here are some vids
suggestions, remove head. gasket match. everything, exhuast mani, intake mani, and the head, also remove casting marks in rotating assembly, knife edge crank,
polish pistons as per endyns site, and follow his rotating assembly mods
Y8 intake manifold (also gasket matched)
b series throttle body (60mm not 58mm first gen b16a)
y8 metal head gasket.
mill,
with the nitrous setup and the crap that you listed you're probably there
mill,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kristian P »</TD></TR><TR><TD CLASS="quote">If you got enough $$ then noting is possible
Dont you mean anything?
</TD></TR></TABLE>Dont you mean anything?
