Crank position sensor
Old Jan 14, 2008 | 09:35 AM
slvcivic00's Avatar
Default Crank position sensor
Just swapped a 94 b18b into my 97 civic. I got the OBDII distributor and everything else. One of the engine codes is for the crank position sensor because i do not have one on the motor. I went out and bought a crank position sensor but it did not bolt up. I was told i also have to go out and buy an oil pump from an integra that is an OBDII. I was wondering if this was true and all that i needed. (I used my stock EX wiring harness.)
Old Jan 14, 2008 | 09:59 PM
4doorekITR's Avatar
Default Re: Crank position sensor (slvcivic00)
you can jump it out,.search it,.JDM obd2 engines dont have the sensor on the crank..only in the distributor...you can jump it out..
jjmcmana
Nov 1, 2008 09:02 AM
eg6civic1538
Apr 15, 2008 04:46 AM
97ekeric
May 24, 2007 04:49 AM
EKB18BPR3
Mar 13, 2005 07:22 PM
Nvious R
Oct 28, 2003 06:27 PM
