gsr internals!
Old Jan 13, 2008 | 09:07 PM
knuckk's Avatar
Default gsr internals!
i blew my ls block recently and i just picked up a gsr block today what parts can i use from a LS on my new gsr block?
&& im not too sure either of the parts i would need to rebuild a block i know i would need the pistons rods rod bearings crankshaft what else am i missing?
Old Jan 13, 2008 | 10:21 PM
92civicx's Avatar
Default Re: gsr internals! (knuckk)
https://honda-tech.com/zerothread/1676914
Old Jan 13, 2008 | 11:29 PM
knuckk's Avatar
Default Re: gsr internals! (92civicx)
ok that doesnt help me at all im looking to see what ls internals can i put in my gsr im not building a ls vtec thats how my block went in the first place im not going back trust me.
Old Jan 14, 2008 | 06:01 AM
mmuller's Avatar
Mad Scientist
you can use all ls internals, you might have to bend the oil squirters a little, but thats it. or plug them
Old Jan 14, 2008 | 08:54 AM
knuckk's Avatar
Default Re: gsr internals! (mmuller)
ok thanks but will i lose any power from the gsr if i use ls internals?
Old Jan 14, 2008 | 08:23 PM
I AM WEASEL's Avatar
depending on what pistons you will be using, you could meke more power than a stock gsr - you are essentially making a stroker motor
Old Jan 15, 2008 | 09:50 AM
knuckk's Avatar
im using stock gsr pistons
Old Jan 15, 2008 | 03:16 PM
SIXTY-1HATCH's Avatar
Default Re: (knuckk)
yep thats a stroker motor, you need to read and search on here about the compression ratio your looking for. I can't get into detail about it, but putting that crank in there adds more stroke, that motor would be a beast with that crank if you do it up right.
other than that, if your not looking to do anything crazy and just use stock parts you really can't use anything, cept maybe the water pump and you would need to get an ls timing belt. i would leave it alone unless someone who really knows hondas puts the ls crank in there.
arielmalespin
Apr 27, 2005 11:24 AM
BoOsTiN Dc2
Dec 11, 2004 10:06 PM
blmracing
Feb 25, 2003 10:15 PM
AndyL
Jun 18, 2002 10:59 AM
