catch can plasement need help
I just baught a endyne catch can and i need to install that and my new motor monts so i can finally get tuned so i really need to get this done soon. My problems is i spent all day today trying to find a spot to mount the damn thing and i couldent i tryed to search for other peoples but i didn't find much the ones i did find were near the battery on the fire wall which is were i wanted mine but it dosent fit bwteen the battery, fuel filter and some evaporation box below the batter. Now i know it has to be as hign as possible which leads me to my questyions i found a spot for it but i dont know if it will be high enopugh the top of the filter on the can will be about the same height as the radiator and the radiator support will this work ?. If this wont work can people send some pic's of theres and or tell me if anyone moved anything to get it to mount near the batter and if so what was it. send some pic if anyone has any please this will be mounted in a 99 civic si
if you are using the endyn as it was designed, it needs to be higher than the ports in which it was designed to flow the oil back to the pan.
this is where mine was:
I was running into the same problem with my catch can setup. So what i did was re-located my battery to the trunk and then placed my catch can where the stock battery location was. Battery relocation is really easy to do. You should look into it...
i put mine on the strut tower and secured it with one of the 10mm bolts that used to hold the wire harness bracket. its the z10 kit btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">i put mine on the strut tower and secured it with one of the 10mm bolts that used to hold the wire harness bracket. its the z10 kit btw
lol mine is in the exact same spot secured with one bolt
</TD></TR></TABLE>lol mine is in the exact same spot secured with one bolt
bluemc
Feb 2, 2012 02:31 PM
