Help - Identify This Motor
Old Jan 12, 2008 | 11:29 AM
Filippo's Avatar
Default Help - Identify This Motor
Hey tech's, bought a new 94 civic hatch today for parts, came with this motor. Definitely a swap but unsure what exact motor type it is. Need your helps guys, thanks :D
*also* if you could tell me the specs of the motor, that would be greatly appreciated*
* i feel so dumb *
haha
Old Jan 12, 2008 | 11:31 AM
silentbeatz's Avatar
Old Jan 12, 2008 | 11:34 AM
Dramier's Avatar
Default Re: Help - Identify This Motor (Filippo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Filippo &raquo;</TD></TR><TR><TD CLASS="quote">Hey tech's, bought a new 94 civic hatch today for parts, came with this motor. Definitely a swap but unsure what exact motor type it is. Need your helps guys, thanks :D
* i feel so dumb *
haha
Looks like a factory D15B7 or D15Z1 MPFI motor. Which would be stock for that car, not a swap.
Old Jan 12, 2008 | 11:36 AM
Filippo's Avatar
Default Re: (silentbeatz)
fixed the pic link**
Old Jan 12, 2008 | 11:37 AM
Filippo's Avatar
Default Re: (Filippo)
i meant it wasnt the original motor that was in the car when produced
Old Jan 12, 2008 | 11:44 AM
BlueIntegraBoy's Avatar
Looks like a D16A6
Copied from Wikipedia:
Found in:
* 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
* 1990-1991 Honda Civic EX Sedan
* 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
* 1989-1996 Rover 216/416 GSi (UK/Europe)
o Displacement : 1590 cm³
o Bore and Stroke : 75 mm X 90 mm
o Compression : 9.1:1
o Power : 115 hp (86 kW) @ 5600 rpm & 95 ft·lbf @ 3,800 rpm, redline 6500 rpm (USA)
+ Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108
o Valvetrain : SOHC
o Fuel Control : OBD-0 four-point PGM-FI
o Head Code : PM3
o Piston Code : PM6
Old Jan 12, 2008 | 11:55 AM
Filippo's Avatar
now that just threw me off course integraboy i dont know who to believe haha
any other opinions folks?
Old Jan 12, 2008 | 11:56 AM
steerh67's Avatar
look for the casting on the block, then you'll know for sure what you have, but to go along with the others, that does look like a factory d
Old Jan 12, 2008 | 11:58 AM
LwdJdmR's Avatar
Default Re: Help - Identify This Motor (steerh67)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steerh67 &raquo;</TD></TR><TR><TD CLASS="quote">look for the casting on the block, then you'll know for sure what you have, but to go along with the others, that does look like a factory d</TD></TR></TABLE>
X2
Old Jan 12, 2008 | 11:59 AM
Filippo's Avatar
i did... no luck but maybe i've had one too many to the head lol, im gonna keep an eye out on this thread for a confident answer lol.. thanks people
Old Jan 12, 2008 | 12:07 PM
Well, first off, it has a PGM-FI on the intake manifold. This only came on the OBD0 engines. Any 92-95 Civic engine does not have this on the manifold.
Plus, if you search D16A6 in the H-T marketplace and Yahoo Images, you get the same looking motor as the one you posted.
Here's an image of a D16A6
http://cgi.ebay.com/ebaymotors...l1247
Old Jan 12, 2008 | 12:10 PM
Filippo's Avatar
Default Re: Help - Identify This Motor (BlueIntegraBoy)
Thanks Blueintegraboy.. greatly appreciated!!
Old Jan 12, 2008 | 12:12 PM
Looks the same to me...
Old Jan 12, 2008 | 12:13 PM
gsrhatch2356's Avatar
there is a stamp right by the trans which tells exactly what motor it is!!
Old Jan 12, 2008 | 12:17 PM
Hanmin's Avatar
Old Jan 12, 2008 | 12:36 PM
redlinexd's Avatar
its most likley a D15B, looks like the one on my friend's DX hatch
Old Jan 12, 2008 | 12:57 PM
Default Re: (redlinexd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinexd &raquo;</TD></TR><TR><TD CLASS="quote">its most likley a D15B, looks like the one on my friend's DX hatch</TD></TR></TABLE>
It's not a D15B (SOHC VTEC). There isn't a VTEC solenoid.
Like I said above, it's most likely a D16A6.
Old Jan 12, 2008 | 01:03 PM
importdreamer's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
I'm voting for d16 a6 based on the pgmfi intake mani. And the valve cover is the same as the one out of my boys 91 crx si.
Old Jan 12, 2008 | 02:46 PM
SoHcEK99's Avatar
Default Re: (importdreamer)
Just look at the sticker on the timing belt/cam gear cover. It should have the same code on it that the block has stamped into it.
Old Jan 12, 2008 | 02:52 PM
Targa250R's Avatar
be professional
The intake manifold and timing belt cover are from a D16A6 or pre-OBD SOHC ZC. Valve cover is pre-'94, if not pre-'92. The distributor is OBD-1 (two gray plugs).
I'm betting it's a D16A6 converted to OBD-1. Check the block stamp to confirm.
1337knub
May 21, 2007 09:08 AM
777
Acura TL, RL & ZDX
Oct 22, 2006 02:20 AM
slowpokecivic
12
Apr 20, 2006 08:21 PM
integradummy91
Aug 29, 2003 09:28 PM
