Cable on back of the tranny
Old Jan 12, 2008 | 07:38 AM
freshvibes's Avatar
Default Cable on back of the tranny
I'm trying to take my motor out but the only thing holding me back is this wire. It goes from the back of the tranny to the fire wall. Anyone know?
Old Jan 12, 2008 | 07:57 AM
crxfreak1117's Avatar
Default Re: Cable on back of the tranny (freshvibes)
that would be the speedo cable just pull it out
Old Jan 12, 2008 | 08:02 AM
Crx Jimmy's Avatar
Default Re: Cable on back of the tranny (crxfreak1117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">that would be the speedo cable just pull it out</TD></TR></TABLE>
No dont just "PULL" it out . pull up the rubber boot at the bottom of the cable remove the weird clip(dont lose it) then pull it straight up and out.
Old Jan 12, 2008 | 08:06 AM
TeamRedline89Hatch's Avatar
Default Re: Cable on back of the tranny (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
No dont just "PULL" it out . pull up the rubber boot at the bottom of the cable remove the weird clip(dont lose it) then pull it straight up and out.</TD></TR></TABLE>
Correct. I made the mistake by "just pulling it" and I broke the clip
Old Jan 12, 2008 | 09:08 AM
freshvibes's Avatar
Ok I've taken off the clip and pulled up the boot and it exposes the wire. Can I just pull it out now? I don't wanna break anything.
Old Jan 12, 2008 | 09:50 AM
ludesrv's Avatar
Once the clip is remove you can pull it out it will simply slip out. Remember when reinstalling it that you need to align the little key with the speed sensor or your speedo wont work once you reinstall it.
Old Jan 12, 2008 | 10:07 AM
freshvibes's Avatar
Default Re: (ludesrv)
I cannot for the life of me get that cable out. The clip is out but the cable won't come out! Is there a trick to this?
Old Jan 12, 2008 | 10:27 AM
ludesrv's Avatar
Default Re: (freshvibes)
Sometimes they stick and the cable breaks. Seen it on a friends old SOHC ZC that I bought off him. I swapped the speed sensor with my old one so I don't have much input other then remove the whole sensor and taking the engine out.
There is a bolt holding where the cable goes into. It's the speed sensor. Once you remove the bolts holding it down just pull up on the sensor (tight fit) and it will come out, then set it aside, remove the engine, and get at it with a better angle by sitting inside the engine bay yourself.
Or, spray lots of degreaser and stuff like that, let it sit for a bit, and go at her again.
Old Jan 12, 2008 | 11:40 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
There are some pics here at the bottom:
https://honda-tech.com/zerothread?id=1325930
Old Jan 12, 2008 | 12:13 PM
freshvibes's Avatar
Default Re: (88DXCRX)
Thanks for the pics. I don't understand how it's so jammed in there. I've stood on the engine and pulled as hard as I could and it still wouldn't budge. Where are these bolts you're talking about? I only see a hole to the right of the sensor that looks like a bolt was there but thats about it.
Old Jan 12, 2008 | 04:41 PM
sanimalp's Avatar
$cat /dev/urandom
can you rotate the transmission a little bit ? that might help free it. like rotate a tire or turn a driveshaft to get it to move a little bit?
Old Jan 13, 2008 | 02:25 AM
freshvibes's Avatar
Default Re: (sanimalp)
That sounds like a good idea. I'll give it a try tomorrow, hopefully it works.
Old Jan 15, 2008 | 06:18 PM
freshvibes's Avatar
That didn't work either. argh... does anyone have a pic of where the bolt that holds the mechanism down is?
Old Jan 15, 2008 | 07:12 PM
bagpipe goatee's Avatar
The bolt is right there, it holds a piece of metal over where the VSS goes into the transmission. Should have a 10mm head. Easy to see. If you don't see it there, it must be gone, taken off by the last poor unfortunate soul to try to remove your VSS. Is the engine in the car? I assume it is. If you can get a new one from a junkyard, you can break it just to get it out of there, and access it better with it out.
Old Jan 15, 2008 | 08:59 PM
EFM_ookie's Avatar
Default Re: (bagpipe goatee)
ya here it is
THE *FOB* MOB
Nov 16, 2016 12:28 PM
BigDawwg6969
Feb 25, 2006 05:35 PM
honcrx91si
Aug 1, 2005 12:47 AM
89civichatchback
Jul 25, 2003 04:16 PM
Artful Dodger
Jun 13, 2003 10:31 AM
