Cigarette lighter/power outlet blows fuses
Old Jan 11, 2008 | 10:45 PM
strsi's Avatar
Default Cigarette lighter/power outlet blows fuses
In my '00 Si the power outlet (spot where the cigarette lighter goes) stopped working.
One day it just stopped working. I checked the fuse and it was blown. So i put in a new fuse, tried it out the the cell phone charger, but it didn't work.
I checked the fuse after trying it, and it was blown again.
All the wires look fine.
What would be causing this?
It just blows the fuse before ever working at all, regardless of what i plug into it.
Old Jan 12, 2008 | 10:40 AM
silentbeatz's Avatar
the wire might be grounding somewhere
Old Jan 12, 2008 | 10:47 AM
Scott.'s Avatar
use bigger fuses bahhah
Old Jan 12, 2008 | 10:48 AM
MilanoCivic97's Avatar
Default Re: (silentbeatz)
theres probably a short somewhere, trace the wires with a multimeter.
Old Jan 12, 2008 | 11:01 AM
projekt-sol's Avatar
Default Re: (MilanoCivic97)
mine did this and it drove me crazy. look down inside the ciggerette lighter and make sure no coins of anything have fallen into there
Old Jan 12, 2008 | 01:05 PM
strsi's Avatar
Default Re: (projekt-sol)
thanks
Old Jan 12, 2008 | 06:38 PM
fastrc2's Avatar
Default Re: (strsi)
use the phone charger properly, or get an adapter for the socket t make it a true utility plug instead of using a cigarette lighter socket as a utility plug the propblem is that you are plugging in a phone charger or other device in there, the reason why is that the contacts on the side of the barrel of the charger happen to line up to the positive contacts that run up the side of the barrel of the lighter socket, all you need to do is turn it 90 degrees so the contacts on the charger dont short the positive to the nearby ground which is the entire walls of the barrel.
Old Jan 12, 2008 | 10:00 PM
strsi's Avatar
Default Re: (fastrc2)
There actually is no cigarette lighter. It says accessory power outlet, or something like that right on the cover for it.
sneaks
Aug 9, 2010 06:01 AM
nightryder21
Honda Civic (2006 - 2015)
Mar 19, 2009 03:42 AM
LsNrG
Audio / Security / Video
Dec 10, 2004 05:24 PM
SpoonIntegra808
Nov 13, 2004 05:51 PM
gsrstyle
Oct 13, 2003 03:42 PM
