07 Accord power plug not working
Re: 07 Accord power plug not working
There are two fuses in the driver's side interior fuse box. Fuse 9(15 AMP) and fuse 32(7.5). Fuse 9 will most likely be blown but before replacing it make sure there is not something down in either accessory socket.. like a penny. If no foriegn object and fuses are blown then replace the fuse and evaluate the device you are plugging into that socket.
check to see if the power supply is plugged into the back of the power plug. i went to use mine once, and the prong on the back of the plug had fallen off
If the power plug is not working,it may be due to loose connection or else its good to go and meet the mechanic,he will give the solution of your problem
user114
02-06-2013 04:17 PM
green eyed bandit
11-16-2011 06:14 AM
strsi
01-12-2008 10:00 PM
