spun bearing
Old Jan 11, 2008 | 09:59 AM
FO SHO's Avatar
Default spun bearing
hey all..i recently bought a crx that has a dohc zc swap and it spun a rod bearing. the crank is a little nicked up but not bad, so i talked to a well known engine builder in the area and he said i could use an undersized bearing just to be sure. so i bought some emery cloth and im gonna try to clean it up a little, do you guys think it will be ok this way? thanks!
Old Jan 11, 2008 | 03:43 PM
Old Renegade's Avatar
just get a crank that is in good condition and go from there. why risk and skimp on a part that endures a lot of stress!!!!!
Old Jan 11, 2008 | 06:36 PM
fin781's Avatar
Default Re: (Old Renegade)
word.......... do not over look it, im the king of half ***, and ive learned my lesson. do it right bro.
Old Jan 11, 2008 | 06:39 PM
GSX 4G63T's Avatar
If honda crankshafts are in need of undersized bearings the crank is to be replaced only.
Old Jan 12, 2008 | 07:58 AM
FO SHO's Avatar
will only a crank out of a zc fit? cause i have a d series block with crank (not sure which one)
Old Jan 13, 2008 | 07:43 AM
FO SHO's Avatar
the block i have is a d16a6, this crank is probably not the same size huh.
t_can
Engine Machining & Assembly
27
Jun 27, 2017 10:23 AM
s032105k
Dec 28, 2010 06:17 PM
DanishR
Oct 7, 2007 07:41 PM
mike93eh
Jan 12, 2006 07:27 PM
S13 slide
Dec 2, 2002 05:54 PM
