ls vtec nitrous help
Old Jan 10, 2008 | 04:27 PM
prhatch124's Avatar
Default ls vtec nitrous help
i was wonderin if i can go with nitrous with this setup i know i have to get it tune but some pep say thatz to high of compression to go with nitrous
JDM B16 SIR II head
new valve guides
new seals
Crower.5mm oversized valves
Skunk2 Ti retainers
Skunk2 springs
3 angle valve job
GE headgasket
blox intake maniflod
70mm bbk tb
new gaskets
b.crower stage 2 cams
95 LS block
bored .20
wiseco 12:1 pistons
Eagle rods
GE block guard
ACL bearings
ARP headstuds
ARP rod studs
ITR oil pump
ITR water pump
ITR timing belt
Old Jan 11, 2008 | 10:45 PM
b.series's Avatar
Default Re: ls vtec nitrous help (prhatch124)
yes u can but on race gas only. and i recommend u get a direct port kit. nitrous loves compression
Old Jan 12, 2008 | 11:12 PM
prhatch124's Avatar
Default Re: ls vtec nitrous help (b.series)
thankz
Old Jan 13, 2008 | 12:31 PM
nitrousballa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.series &raquo;</TD></TR><TR><TD CLASS="quote">yes u can but on race gas only. and i recommend u get a direct port kit. nitrous loves compression</TD></TR></TABLE>
NITROUS CREATES THE COMPRESSION......flat tops are the base of a nitrous
motor if you want to make alot of power.nitrous also does not like restrictions either.there are plenty of nitrous threads on here so feel free
to indulge.
bertsb18hatch
Sep 15, 2009 08:41 PM
prhatch124
Feb 5, 2008 06:21 PM
JadeGreenEF9
Feb 8, 2007 01:46 PM
g-ride-si
Feb 2, 2006 12:16 PM
lsvtec94
Aug 9, 2002 12:30 PM
