Small Surface Rust Removal
Old Jan 10, 2008 | 09:33 AM
steveo135's Avatar
Default Small Surface Rust Removal
Ok so I recently purchased this car from New Jersey... The thing is basically rust free but I noticed these two rust spots... I want to remove them before they become something big...
I was thinking use fine sand paper to take it down to the metal, then mask off the area and use some combination of either primer and duplicolor (the little tube w/ brush from autozone), or rustoleum and duplicolor, or just rustoleum...
Not too much of an idea what im doing... any suggestions?
And some pics of the rust to get an idea of what im talking about...
Thanks for any help!
Old Jan 10, 2008 | 09:46 AM
iam7head's Avatar
Default Re: Small Surface Rust Removal (steveo135)
well, you will not able to get rid of it unless you go down to the metal, something more like 220 grit.
once you have the area clean up, you can spot repair it with a mini gun(small hvlp gun, not the one they use in helicopter), don't use crap paint from homedepot, it will stand miles away.
with a good feather edge and polish job, u can't even tell it's there in the first place.
Old Jan 10, 2008 | 10:03 AM
steveo135's Avatar
Default Re: Small Surface Rust Removal (iam7head)
see thats the problem I dont have a compressor or a spray gun... I was thinking of doing this as kind of a temporary fix untill I invest in a compressor and all that stuff...
Old Jan 10, 2008 | 12:03 PM
doubleshotz's Avatar
DA sander is your best friend for surface rust.
Old Jan 10, 2008 | 12:34 PM
RiskEverything's Avatar
Default Re: Small Surface Rust Removal (doubleshotz)
For the trunk lid: sand it down, tape it off, and spray-paint it with Rustoleum. Then put a bumper sticker over it.
For the door, sand it down and repaint it with matching touch-up paint. Put a coat of wax over it.
That'll do well enough until you get proper equipment.
fightingirish61
Paint and Body
Feb 5, 2014 06:08 PM
civicpraning2k1
Detailing
Aug 8, 2009 08:18 PM
komat
Jan 25, 2005 08:34 AM
etmoron
15
Jun 11, 2003 05:00 PM
95civiccoupe31
13
May 29, 2002 06:38 AM
