EGR VALVE??? 97HXmotor
Old Jan 8, 2008 | 12:35 PM
JDM_CRX_PLEASE's Avatar
Default EGR VALVE??? 97HXmotor
hello i have a 97 HX motor and it has a egr valve. i was wondering if the car would work without it being pluged? cause i want to put a 99-00 SI harness on it and i dont think si harness has EGR plug.. thanks
Old Jan 8, 2008 | 12:42 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: EGR VALVE??? 97HXmotor (JDM_CRX_PLEASE)
1. You're right - 99-00 Si harness lacks EGR anything
2. Why are you putting the harness in the car?
3. What ECU are you going to run?
4. What engine?
Old Jan 8, 2008 | 12:48 PM
thesmogman's Avatar
Default Re: EGR VALVE??? 97HXmotor (B18C5-EH2)
If the ECU is not going to look for it then block it off. Just make a piece out of steel and drill and shape it and bolt it up. Copy the EGR valve base when you pull it.
Wait... did I say that?
Old Jan 8, 2008 | 12:50 PM
because i cant find a 99-00 HX harness. im putting this 97 motor in my 00 chassi. so i needed a 0bd2b HX harness but can only find SI's. im runnin the 97 HX ecu i already got a jumpr harness for it
Old Jan 8, 2008 | 12:53 PM
hall97civic's Avatar
Default Re: EGR VALVE??? 97HXmotor (thesmogman)
first off, like someone else said, why are you putting an si harness on the car? second, your car will run fine without the egr, except for it won't get quite as good gas milage and you will get a cel. And for whoever asked, I beleive that we are talking about a y5.
later
Old Jan 8, 2008 | 12:57 PM
Default Re: EGR VALVE??? 97HXmotor (hall97civic)
did u read what i just wrote?
Old Jan 8, 2008 | 01:24 PM
thesmogman's Avatar
You might want to rethink your choice. In CA motor swaps have to be the same year or newer. You can not put an older motor in a newer car. You can't even BAR ref it.
Now if it's a track only car then......I will shut up.
Old Jan 8, 2008 | 01:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">did u read what i just wrote?</TD></TR></TABLE>
yeah I did, but when you posted your reply, I was typing mine, so I didn't read until after I had posted. jackass . Anyways, if you end up changing your plans and hooking up the egr valve, you should clean out the egr plenum because they get plugged up with carbon and will effect your gas milage, as will simply unhooking the egr valve. When my plenum was plugged up, my engine would run so lean that it would missfire when the egr valve was open, so I unplugged it for a tank of gas(until i had time to fix it) and it took my milage from 40 down to 33 or so.
good luck
Old Jan 8, 2008 | 02:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">You might want to rethink your choice. In CA motor swaps have to be the same year or newer. You can not put an older motor in a newer car. You can't even BAR ref it.
Now if it's a track only car then......I will shut up.</TD></TR></TABLE>
i dont need to bar a single cam.
Old Jan 8, 2008 | 04:49 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">You might want to rethink your choice. In CA motor swaps have to be the same year or newer. You can not put an older motor in a newer car. You can't even BAR ref it.</TD></TR></TABLE>
You don't need to ref a motor if it is an exact stock replacement. And if it is older, well, nobody will ever know. But even if you upgrade SOHC motors, there is a VERY good chance that your typical smog check station will never know you made the change.
aavtec
19
Jan 24, 2013 02:46 PM
JDM_CRX_PLEASE
Dec 30, 2007 07:54 AM
who-got-rice
Nov 10, 2006 11:26 AM
Biloxi
Jan 3, 2005 12:13 AM
seek167
Jun 24, 2004 08:10 AM
