Idling problem, cleaned the IACV...
Old Jan 8, 2008 | 10:08 AM
Morasso's Avatar
Default Idling problem, cleaned the IACV...
So I just got an EG and I have the infamous idling issue. It has a D15 just for reference.
My idle will spike from 1 to 2 then drop back down to 1 and repeat. It almost sounds like im reving.
I searched and cleaned my IACV but its still doing it, are there any other options, its really annoying.... Also the little gasket that goes between he IACV and the intake manifold if thats missing could that cause the idling issue? When I took my IACV off I couldnt see that gasket, but I found some, almost glue like crap in the groove, I figured the gasket was still attached to the intake mani or something, could buying a new gasket possible fix this issue?
Old Jan 8, 2008 | 10:42 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Idling problem, cleaned the IACV... (Morasso)
yes that gasket missing will cause your issues homie
Old Jan 8, 2008 | 10:45 AM
crazyguy's Avatar
Default Re: Idling problem, cleaned the IACV... (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">yes that gasket missing will cause your issues homie </TD></TR></TABLE>
+1 and also check for your vacume leak
Old Jan 8, 2008 | 10:51 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Idling problem, cleaned the IACV... (crazyguy)
Him missing that gasket is a vaccum leak.
Old Jan 8, 2008 | 11:00 AM
Morasso's Avatar
Word, I'll go pick up a new gasket today.
Also cleaning my FITV for good measure.
Thanks Kevin!
Old Jan 8, 2008 | 11:19 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Him missing that gasket is a vaccum leak.</TD></TR></TABLE>
my bad.
Old Jan 8, 2008 | 11:34 AM
Morasso's Avatar
Cleaning the FITV did it! Thanks anyway guys, I guess the gasket is still in there, just on the intake mani side.
Old Feb 3, 2008 | 10:00 AM
greentea.ek's Avatar
what is the FITV A LIL LOST ON THE ABREVIATIONS .....DIDN'T REALY PASS NOTES IN SCHOOL
actionfigure
Jan 7, 2007 07:06 AM
SECURITY
18
Jul 28, 2005 10:21 PM
skater5067
Apr 22, 2005 08:24 AM
joecivic93
Jan 3, 2004 10:25 PM
ULTRA911
Mar 4, 2003 10:00 AM
