Leak from intake manifold gasket causes low or high idle?
just need a couple of replies, thanks!
[Modified by ULTRA911, 10:24 AM 2/17/2003]
Re: Leak from intake manifold gasket causes low or high idle? (1bad-eg)
Can this be fixed without going through the trouble of changing the gasket? Is there some kind of sealant that can be put around the edges of the gasket?
Re: Leak from intake manifold gasket causes low or high idle? (blacksheep)
If it is the upper gasket, its not a big deal to replace. Takes about 15-20 minutes to take off, replace the gasket and re-attach the intake plenum. The lower gasket requires a little more effort. A vacuum leak like that will cause more than a high idle, though.. you will probably be running pretty rich and have a crappy idle as well. rough, etc. Possibly throwing EGR codes as well.
singlecammin
01-20-2011 07:20 PM
Morasso
02-03-2008 10:00 AM
