Camshaft cover problem
The valvecover? take all the bolts out then pry it off with a flat head screwdriver. Over time, the gasket will get sticky from heat and oil. perfectly normal. Its metal, you wont hurt it. Now, if it takes a pry bar, then you're doing something wrong.
From: I told you to wait in the truck in Texas, United States
Take out all four nuts, (assuming it is a D-15 or D-16)
Then use a pick to remove the four grommets...
Then take a dead-blow hammer and tap it on the ends
and sides and it should break loose.
As a last resort,You could take the oil cap off and pry gently
between the rocker arms and the cover..
Yuta
Dec 12, 2015 05:27 PM
civicEXtreme
10
Jan 29, 2006 03:00 PM
