Need help.
Old Jan 7, 2008 | 08:27 AM
LifeMage's Avatar
Default Need help.
trying to wire up my turbo timer and i ran into some issues. first off i have a 96 ls integra i have a greddy turbo timer but when i ran the wires i have found all the spots that i needed for the wires to be ran to but i found some sort of a aftermarket alarm system that will not let my car start without it in there but should i wire it up to that or? any help would be awsome!!! here are some pictures that should help with the problem
Old Jan 7, 2008 | 09:02 AM
jhammond_82's Avatar
Reject Papi
Default Re: Need help. (LifeMage)
what good is a turbo timer? all it does is allow your engine, which is already hot, to continue to run, not getting any cooler, and there is no airflow to even remotely help cool it down.
Old Jan 7, 2008 | 09:06 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: Need help. (jhammond_82)
well turbo timer is a good product, first off i had a turbo hatchback civic and every time id step on it, it wud get hot so i waited a 1min till it cooled down then shut off the car, this is to allow the oil to run threw the turbo and cool it down a bit, a turbo timer is set to a time when to shut off the engine, its just to run oil through the turbo and it does help, ps i had an oil cooler as well, its a must to let turbo car run to cool down
Old Jan 7, 2008 | 09:07 AM
Default Re: Need help. (DOHCgarage919)
so basically its to cool down the turbo not the engine
Old Jan 7, 2008 | 05:08 PM
LifeMage's Avatar
anyone have any wireing help for me please?
Old Jan 7, 2008 | 08:01 PM
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">so basically its to cool down the turbo not the engine</TD></TR></TABLE> i know this, i'm not an idiot. but wouldn't hot exhaust gasses that are still generating throught the turbo keep it hot? i mean, exhaust doesn't get any colder by running longer, know what i mean? i know what they are for, and what they are intended to do, i just never understood the concept, IMO its a waste of 100 bucks.
Old Jan 7, 2008 | 08:22 PM
it cools the TURBO PERIOD! think of it this way say ive been stepping on my car the whole day, then i pull into my drive way,ok now my turbo is super hot and so is the oil in there, if i shut it off right away its still gonna be hot and the cooler oil isnt gonna run threw the turbo cuz car is off, this is why you let it run a while, and if you have an oil cooler like i did its even more effective, and i hope you know that oil runs threw the turbo as well not just "gases" the internals of the turbo need to cool down, and oil does cool down, why do we have oil coolers then?? oil doesnt stay in one place of the motor is circlates which cools it down a bit, again oil cooler more effective
Old Jan 7, 2008 | 08:37 PM
Reject Papi
ok, like i said, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote"> i know this, i'm not an idiot. IMO its a waste of 100 bucks. </TD></TR></TABLE> i've had a 1990 ford probe gt, its stock, its my dd, i've had it for 4 years, when i bought it, it had 180,xxx on the clock. i installed turbo timer, and a front mount, and an eclipse bov, i ran low on some money, and i sold the bov, and timer, i saw absolutely no difference, except for sound, now, 4 years later i have all stock motor, and well over 250,xxx on it, and no problem, i guess its just a matter of opinion, i'm not aguing, i'm just saying that IMO i could find something better to spend my money on. if you and the op like it, cool. just for me.....
Old Jan 7, 2008 | 08:45 PM
man you dont get it , i know your motor is good and still runs and lasts long, its about the life of the turbo! its made out of cast iron , so if its too hot it will crack, so if you let it run a lil bit too cool down it will increase the turbos life,
Old Jan 7, 2008 | 09:02 PM
St Jimmy's Avatar
* B A N N E D *
Those 2 black wires coming out of the alarm should be hooked to the ignition after the white connector. Usually you just cut the oem ignition wire in half and run one of those black wires to each side (to install the kill switch), so if you connect those 2 black wires it should be ok and start fine with the alarm taken out.
Modified by St Jimmy at 10:14 PM 1/7/2008
Old Jan 8, 2008 | 03:04 AM
mike5809's Avatar
I don’t think that kid understands what a turbo timer does. I had one on my talon. You are not going to notice any 'difference' in power or anything. it is just a preventative measure to help protect your turbo and ensure longevity of it. It is just to cool the turbo down. Everything really needed to explain it simply has been said. Sure you could run your turbo with out it and never have problems, same goes for a rev limiter but would you run without one of those? Most people wouldn’t, might as well do all necessary precautions so you can hopefully eliminate problems down the road.
As far the alarm cant you just bypass it or take the fuses out assuming you don’t want the alarm? If you did want it then I am unsure.
Old Jan 8, 2008 | 06:46 AM
Reject Papi
Default Re: Need help. (mike5809)
dude i'm not a expletiveing kid i'm older than you, and i'm not a expletiveing idiot, i know what a turbo timer does, its not a performance part, i know that. but with 250,000 miles on stock, how much longer do i need it to last? know what i mean. thats alot of miles and no cool down, huh? and it spools 12 psi. on a daily basis. i do know that it "helps" cool the turbo down, but like i have posted 3 times now, its my opinion.
Old Jan 8, 2008 | 06:58 AM
mike5809's Avatar
Sorry to 'misunderstand' you, my fault.
I was boostin 22 psi ony my Talon and i liked the 'added comfort' of the turbo timer. I guess to each his own.
Old Jan 8, 2008 | 07:07 AM
Reject Papi
http://en.wikipedia.org/wiki/Turbo_timer in there it says that it can be eliminated by not boosting the last few minutes of run time. and i don't usually boost in my developement on my way home from work, at night. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">I guess to each his own.</TD></TR></TABLE> agreed.
400WHPITR
Mar 21, 2003 01:20 PM
rbf351
Audio / Security / Video
Nov 23, 2002 06:06 PM
MugenHonda
Nov 4, 2002 12:38 PM
curiousgpnoy
Sep 26, 2002 05:01 PM
