Head Milling Question?????
Old Jan 4, 2008 | 04:46 PM
TomsDC's Avatar
Default Head Milling Question?????
Im a NOOB so be nice please. I know an american V8 head can be milled so what do i need to do so i can mill my LS head? i know i need to do something with the Timing Belt. but what else? is it worth it? has anyone had good luck with it?
Old Jan 4, 2008 | 05:32 PM
Mikey3000's Avatar
Default Re: Head Milling Question????? (TomsDC)
the timing belt tensioner will automatically compensate for difference in height. are u trying to get higher compression or flatten it?
Old Jan 4, 2008 | 08:26 PM
TomsDC's Avatar
Default Re: Head Milling Question????? (Mikey3000)
Im shooting for Higher compression. im going to do some B16 pistons too.
Old Jan 5, 2008 | 08:26 AM
Fkned's Avatar
has been covered many many times .Try the search button.
Old Jan 5, 2008 | 08:55 AM
projEKtjokes's Avatar
b16 pistons with a milled head is gonna be a bad choice. I would go with one or the other.
Old Jan 5, 2008 | 04:26 PM
TomsDC's Avatar
Default Re: (projEKtjokes)
okay i researched it on here and its been done but im still unsure if its worth it. what one is better High comp pistons or mill the head?
Old Jan 5, 2008 | 10:21 PM
Turbo B18C EJ6's Avatar
Default Re: (TomsDC)
I personally wouldnt bother milling the head, your better off going aftermarket for hi compression pistons through cp or je , wiseco. or u can do a ls-vtec setup and scrap the ls head. up to you GL.
EfJosh
Nov 15, 2009 11:29 AM
BLU CIVIC
11
Nov 3, 2009 05:35 AM
Y2A
Mar 4, 2005 09:03 AM
vti2
Jul 5, 2004 08:13 PM
Peter K
Jul 1, 2002 05:14 PM
