Wheel wobble?
Hey on my 88 dx i have a minor wheel wobble on the left front tire and was just wondering what the most probably cause of this is, thanks.
and i was also wanting to know what a good suspension setup would be because i would like to get new shocks etc...
and what tools i would need to do it myself
youre knuckle / hub maybe ?
jack youre car up and lock the wheel. put your hands on both sides of em them and try and wiggle it by pullin and pushing . know what im sayin ?
if thats loose you probably need new hubs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe »</TD></TR><TR><TD CLASS="quote">ya same thing happened to me a few months back and i changed out my wheel bearing and got a new hub/ knuckle assembly</TD></TR></TABLE>
where'd you buy your hubs from?
yeah jack up the car.
and shake the wheel left to right and its your rac-
top to bottom is your wheel bearing.
check your tire and make shure it dosent have a bubble in it.
and check you axel. it good be off balanced.
if your driving and your steering wheel is going left and right that your rac-
dose it only happen when your giving it gas or all the time while your driving?
I am experiencing the same problem as well, I found it after I got my alignment done. It moves back n forth, the wheel jerks when i hit a little dip or bump, and the steering is not as responsive as before, like if i was parked and try to turn the wheel, it would have a little play in when it would start turning..
Check lugs if tight proceed
Jack car up with jack and jack points
Put on jack stands
Grab wheel at 12/6 o'clock and shake, does it wobble a lot ? If so check out the ball joints and wheel bearing, a wheel bearing will also cause a noise though when going bad. Sounds like a humming noise. If nothing of the sorts is occuring move on
Grab wheel at 3/9 o'clock and shake, does it wobble a lot ? If so look into the tire rods or possible wheel bearing.
If you suspect a bad wheel bearing, take the wheel off and move the hub ( what the lug nuts thread onto ) and see if it wobbles.
Other things to keep in mind, wheels being balanced, rotor warped.
Put on jack stands
