i need some help
Old Jan 3, 2008 | 09:55 AM
IMPORT_IMAGE's Avatar
Default i need some help
i have a 93 civic ex with a gsr motor the motor is good but the tranny is givin me a lil problem...the problem is when i step on it and try to change from 2 to 3 it grinds but it only happens when its at high rpms other then that when i drive normal it dont do it....
Old Jan 3, 2008 | 09:59 AM
philosofy1's Avatar
Default Re: i need some help (IMPORT_IMAGE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 civic ex with a gsr motor the motor is good but the tranny is givin me a lil problem...the problem is when i step on it and try to change from 2 to 3 it grinds but it only happens when its at high rpms other then that when i drive normal it dont do it....</TD></TR></TABLE>
you can try changing your tranny fluid and see if that helps, but it sounds like your syncros are going bad.
Old Jan 3, 2008 | 10:01 AM
wut kind of fluid should i get ?
OMGWTFBBQ!'s Avatar
Buy a new tranny?
Old Jan 3, 2008 | 10:05 AM
philosofy1's Avatar
Default Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! &raquo;</TD></TR><TR><TD CLASS="quote">Buy a new tranny?</TD></TR></TABLE>
SHHH!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE &raquo;</TD></TR><TR><TD CLASS="quote">wut kind of fluid should i get ?</TD></TR></TABLE>
Honda's manual transmission fluid is the best, so stick with it.
snatch
Dec 13, 2005 11:23 AM
JSPECCRX
Mar 7, 2005 06:33 AM
volcom_20
Dec 5, 2004 06:32 AM
LorenGeist
Aug 14, 2004 12:05 PM
jerbear!
Mar 16, 2004 09:47 AM
