95 auto civic swap
Old Jan 2, 2008 | 06:18 PM
90b18teg's Avatar
Default 95 auto civic swap
Ok I am looking to do a motor swap in my 95 auto civic.. I had a a ls motor for it but it didnt fit right I would have had to cut something and didnt want to do that..I was looking at the 92-95 DOHC zc swap and was wondering if that would fit with out having to cut anything.If you could help me out and let me know what i can swap my stock motor with I would prefer something DOHC let me know thanx
Old Jan 2, 2008 | 06:33 PM
mini-meEj1's Avatar
Default Re: 95 auto civic swap (90b18teg)
i wouldn't think you had to "cut" anything to actually get it to fit in there would be using b-series mounts
Old Jan 2, 2008 | 06:37 PM
z6hatchboy's Avatar
like mini-me said, use the b-series mounts or some hasports, i dont see why that ls wouldnt work but, if you want a another dohc, just get a b16 (which mouts the same as a ls i believe).
Old Jan 2, 2008 | 06:40 PM
mini-meEj1's Avatar
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">, just get a b16 (which mouts the same as a ls i believe).</TD></TR></TABLE>
i believe you are correct, all b-series mounts are the same.
Old Jan 2, 2008 | 06:42 PM
90b18teg's Avatar
the alt hits on rear fire wall and the rear tranny mount hits before they line up and i need a swap for and automatic i dont want to change it to 5 speed
Old Jan 2, 2008 | 06:46 PM
Luserkid's Avatar
You need the auto to manual mount.
Old Jan 2, 2008 | 06:51 PM
90b18teg's Avatar
I would swap it to 5 speed but it is my wifes car and she likes the automatic.. I have never had a problem like this before. I swapped my teg with a type r and that was easy but this is giving me trouble. I have done a few swaps but cannot figure this one out.
Old Jan 2, 2008 | 06:53 PM
mini-meEj1's Avatar
maybe an auto ls tranny mount?
Old Jan 2, 2008 | 06:56 PM
Luserkid's Avatar
Default Re: 95 auto civic swap (mini-meEj1)
Oh ok, i thought you were doing an auto to manual swap. You should be using all auto Integra mounts/brackets. What mounts are you using?
Old Jan 2, 2008 | 07:30 PM
KURUPTinc's Avatar
Default Re: 95 auto civic swap (Luserkid)
yeah i thought you were supposed to use the engine brackets and tranny brackets from a 94 up integra and use b series mounts???
Old Jan 2, 2008 | 07:48 PM
90b18teg's Avatar
i used all the auto ls mounts that came with the swap ......Does anyone know if the DOHC d16 zc swap would would fit without cutting anything
Old Jan 3, 2008 | 11:32 AM
90b18teg's Avatar
bump
Old Jan 3, 2008 | 08:09 PM
KURUPTinc's Avatar
yeah the mounts but what about the engine brackets that attach to the mounts they have to be 94 and up tegs
hasty91ef
Jun 28, 2011 10:56 PM
detour94civic
Honda Civic (2001 - 2005)
Dec 27, 2010 06:04 PM
HuDey81
Jan 2, 2007 10:10 AM
Fobstylez
Mar 10, 2005 01:12 AM
Myh4tch
17
Nov 16, 2003 12:36 PM
