Cams and Pistons Question
Old Jan 2, 2008 | 09:12 AM
0c00l's Avatar
Default Cams and Pistons Question
I have searched all over and have not found an exact answer to my confusion or lack of knowledge. I am building an Ls/Vtec and this is my first racing engine build. I am not sure what cams to go with becuase I plan on turboing the setup later on. I have a B18A1 block and a B16A1(PR3) head. I have looked at Skunk and buddyclub and crane cams my confusion is Crane cams website shows the set of cams that I want require 12:1 compression pistons which would make turboing out of the question. Is it possible to get cams that can handle 9k rpm revs and be turboed as well? Or is it a one or the other thing kinda build? I just want to make sure the cams I buy will work for my application. Thanks
Old Jan 3, 2008 | 08:17 AM
0c00l's Avatar
Default Re: Cams and Pistons Question (0c00l)
I guess what im asking here is what is the relationship between piston and cam as far as ratios go. Would a combonation of Lower compression pistons be a bad idea as far as running these bigger lobe cams?
Old Jan 3, 2008 | 11:03 AM
quicksilver1689's Avatar
i ♥ snails
for all motor in a performance aspect yes, for boost should be fine alot of guys run some pretty "aggressive" cam profiles with there boosted setups and have good results
Old Jan 3, 2008 | 11:18 AM
Lubo_25's Avatar
boost-stock cams
na-agressive cams(decision based on compression, intake, exhaust mods)
Old Jan 3, 2008 | 11:43 AM
0c00l's Avatar
Thanks again fellas! always informative here!
Superdragr45
Honda Motorcycles
Mar 26, 2009 12:50 PM
Youlose1305
Jun 27, 2006 10:19 PM
4LugR
Nov 24, 2005 06:40 PM
ACrite3404
Jan 24, 2005 10:58 PM
