gauge help?
Old Jan 2, 2008 | 07:47 AM
nix94delsol's Avatar
Default gauge help?
i recently took the needles off the gauges and had my brother dip them in amber stuff at his work...
after putting them back on and starting my car the RPM spikes to 4 and my speedometer flies up to 40
hoooow do i fix this?
Old Jan 2, 2008 | 09:14 AM
slacks's Avatar
Default Re: gauge help? (nix94delsol)
what was the amber "stuff"?
i think the speedo needles respond to a copper solenoid in the cluster and could have set them off with the "amber stuff"
just my crappy .02
Old Jan 2, 2008 | 09:35 AM
Relic1's Avatar
you do realize that the needles are rotationally calibrated correct? (ie placed on the shaft of the rotational assembly at a specific clock position)
if you pulled the needles and didn't mark the position they sag to (without the pin in place) then you wil either have to calibrate them or have someone do it for you.
I've gone through how to set the needles before. I'll try to search through my threads and find where I typed it up.
**edit**
the following are asuming that your car works correctly to begin with
speedo/tach
https://honda-tech.com/zerothread?id=2147081
another speedo
https://honda-tech.com/zerothread?id=2163186
same concept with the fuel and temp.
fuel - fill up the tank, push needle on just above the F
temp - drive around for a while till car is fully warmed up, let idle till fan kicks on and off, push needle on at center.
Old Jan 2, 2008 | 11:00 AM
Default Re: (Relic1)
Relic you are the man
thanks!
Old Jan 2, 2008 | 11:25 AM
Relic1's Avatar
glad it helped, just note. thsoe methods are crude at best.
to be accurate again it takes some serious equipment. (a dyno can be used, but best is a function generator and o-scope)
Old Jan 2, 2008 | 11:33 AM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">glad it helped, just note. thsoe methods are crude at best.
to be accurate again it takes some serious equipment. (a dyno can be used, but best is a function generator and o-scope)</TD></TR></TABLE>
You can use GPS... for speed..
Old Jan 2, 2008 | 11:38 AM
ifIexplode's Avatar
you could use a GPS for speed.
But with my steel wheels the GPS is off by a few mph, And when i have my SI wheels on its matched perfect with my speedo
SOHC_civic_si
Feb 17, 2009 03:38 PM
Dave4282
Feb 12, 2007 09:06 PM
jdmintegls
Sep 22, 2004 02:58 PM
96_GSR
Mar 22, 2003 06:05 AM
Lynx
Nov 1, 2001 12:28 PM
