d15b compression
Can't be sure for the d15, but the readings on my d16 was 180psi, as long as youre within 25psi cylinder to cylinder(these are factory specs) you shouldn't be too bad off.
Re: (OMGWTFBBQ!)
what he ^^ said
As long as the readings are consistent (and not stupidly low) thats the important part - if you get 170 175 165 35 you're screwed but if you get 185 195 180 185 you're fine... just look for something consistent above 150ish (i don't know your gauge, but that seems like a good number) if stuff is failing, it won't all fail equally and it won't fail just a little.
