dexron
so i know that quite a few people use Sea Foam in their vacuum lines and such, so i brought it up with a mechanic. He said that instead of using seafoam, use DEXRON transmission fluid.
has anyone ever done this?
Negatory...That is new to me. I've heard of adding ATF to your oil before an oil change (which I don't do), but have not heard of adding ATF into vacuum lines.
To me, it seems like the thickness of ATF might cause it to gooop up in the hoses...but I could be wrong.
my bad,
i did not mean put dexron into the vacuum line. He said instead of putting seafoam into the vacuum line, put in into the gas on the next fill up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRZ88DX »</TD></TR><TR><TD CLASS="quote">my bad,
i did not mean put dexron into the vacuum line. He said instead of putting seafoam into the vacuum line, put in into the gas on the next fill up.</TD></TR></TABLE>
Do not put it into the fuel tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Do not put it into the fuel tank.</TD></TR></TABLE>
gotcha
gotcha
Please don't even use it. If you are about to do any of the things mentioned above....then you are not ready to do any kind of cleaner cheat.
Please, just don't muck up your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">Please don't even use it. If you are about to do any of the things mentioned above....then you are not ready to do any kind of cleaner cheat.
Please, just don't muck up your car.</TD></TR></TABLE>
no Dexron
just gonna do the <U>SeaFoam</U> before next oil change
no Dexron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Sea Foam use is well-documented on these forums. Do a search in the archives and read the various threads on it for tips.</TD></TR></TABLE>
i've looked through every seafoam thread, i think all will be ok. as for the Dexron . . . *throws into fire* "WAIT! uh-oh!! *runs from explosion*
ATF has cleaners inside the fluid itself. Adding a liter to your oil and running it for 5-10 minutes before the oil change can clean out some gunk on the inside of the crank case. Don't forget to run thru some oil during the oil change to help make sure most of the ATF is gone.
Seafoam, cleans an entire different part of the engine. It cleans the intake manifold and combustion chamber by adding a harsh cleaning chemical to your air/fuel mixture during combustion. It really works in taking off carbon build up and I do it to my car every 6 months to help improove reliability, driveability and fuel efficiency.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si-Samuri »</TD></TR><TR><TD CLASS="quote">hmmm not a fan of cheater cleaners but good info.</TD></TR></TABLE>
but there so fun!
but there so fun!
stackz
Feb 28, 2008 01:49 PM
*Boostwerks*
Aug 22, 2003 08:54 AM
