Ball Joint Install Help 94 civic
I already searched but i cant find exactly what im lookin for...anyways well i had to replace the whole passenger front knuckle recently and everything bolted right back up fine EXCEPT the ball joint that connects to the upper control arm, i cant get the nut to tighten up so i can put the lil pin back in cuz the bolt turns with the nut....what have i done wrong...all help is appreciated!
-Jeremy
-Jeremy
use a big pry bar to force the ball joint/control arm down into the knuckle. usually works pretty good. even better with air tools. the threads arent messed up on the nut or the ball joint are they?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHRESH »</TD></TR><TR><TD CLASS="quote">does it have to be pressed on?</TD></TR></TABLE>
the lower ball joint has to be pressed in but upper low ball joint cant, u need to buy the whole arm
overurhead360
Mar 17, 2010 12:54 PM
chibiko
Jun 6, 2007 08:45 PM
frelshonda
Nov 11, 2005 12:24 AM
rasinhell
Feb 3, 2005 01:47 PM
