Spring Compressor Needed to put in OEM Shocks/Springs?
Old Dec 30, 2007 | 10:59 PM
Understeer's Avatar
Default Spring Compressor Needed to put in OEM Shocks/Springs?
I am putting my OEM suspension back in on my 01 Integra. Do I need a spring compressor to put it back?
I was thinking that I can put the shock/spring in the car and jack up the arms to compress it while everything is on the car. Would that work? Or would everything need to be fully assembled before actually putting it on the car?
Thanks.
Old Dec 30, 2007 | 11:09 PM
qwk db8's Avatar
Default Re: Spring Compressor Needed to put in OEM Shocks/Springs? (Understeer)
yes you will need one..
Old Dec 30, 2007 | 11:19 PM
Jtuned DC2's Avatar
* B A N N E D *
definatly gonna need one
Old Dec 30, 2007 | 11:32 PM
Blahblah718293's Avatar
Default Re: (Jtuned DC2)
i think if the shock/spring is already assembled then no, but if its all in peices... then you will need it.
Old Dec 30, 2007 | 11:34 PM
qwk db8's Avatar
Default Re: (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">i think if the shock/spring is already assembled then no, but if its all in peices... then you will need it.</TD></TR></TABLE>
Old Dec 31, 2007 | 12:52 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: (qwk db8)
i never need a compressor just press down on it hard as hell and tighten the bolt, i never used one
Old Dec 31, 2007 | 02:57 AM
sg's Avatar
sg
Default Re: (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">i never need a compressor just press down on it hard as hell and tighten the bolt, i never used one</TD></TR></TABLE>
ill say its the lazy way but i admit i did this with my high mileage OEM springs, the only advice i can give you is have a friend hold it down with his weight while you get the center nut on. its really hard and can be dangerous by yourself
but if these are newer oem springs i recommend using the compressor.
Old Dec 31, 2007 | 04:34 AM
JDM_CRX_PLEASE's Avatar
i remmeber one time i was helping my friend install his new suspension and we needed to compress the rear springs a bit so that we can screw the top bolt on but he didnt rent the spring compressor. so what i did was lift his integra with a 2 ton jack and i put the spring under it and droped the car on it a bit and i just put 5 zip ties on it and raised the car. it workd fine, we put it in then cut the zip ties off after.
idunno if anyone else has ever done that, but thats what i call some good old fashion thinking
Old Dec 31, 2007 | 06:32 AM
JDM knowledge's Avatar
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">i remmeber one time i was helping my friend install his new suspension and we needed to compress the rear springs a bit so that we can screw the top bolt on but he didnt rent the spring compressor. so what i did was lift his integra with a 2 ton jack and i put the spring under it and droped the car on it a bit and i just put 5 zip ties on it and raised the car. it workd fine, we put it in then cut the zip ties off after.
idunno if anyone else has ever done that, but thats what i call some good old fashion thinking </TD></TR></TABLE> haha i like that idea
Old Dec 31, 2007 | 06:45 AM
jtracing919's Avatar
autozone rents them
Old Dec 31, 2007 | 07:00 AM
Understeer's Avatar
Yeah the OEM shocks and springs are NOT assembled yet.
beastman@
Suspension & Brakes
Jul 3, 2008 04:58 AM
HondamanXxX
19
Jun 21, 2007 04:30 PM
budget
Jun 30, 2006 10:45 AM
mike9571
Nov 28, 2005 01:12 PM
Lo-Buck EF
Nov 17, 2002 05:27 AM
