Do You need to remove Intake Manifold to install knock sensor?
My friends knock sensor broke, and i went under the car to try and remove the old one, but couldn't, there was hardly any room to do anything. The only way i can think of to install the knock sensor is to remove intake manifold, But is there a way to install it without having to remove Intake Manifold, any help is appreciated, and thanks in advance for any input. BTW his car is 96 with a Y8
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
you shouldn't have to on any civic i can think of what kind of motor?
My friend has a d16y8, and his Check Engine is on. and we threw a cell and the code was for the knock sensor, and i saw that the knock sensor was broken. his car is obd-2
if the engine is still in the car then u might have to unless u can get under the car and get a deep socket over the sensor..ive tried takin a knock sensors from a b16 off that was in a crx and i had to bcuzz there was no way i could get it from the bottom
You could get it from either the bottom or the top (i find the top easiest). Youll need a deep 1/2 inch 25mm (or it might be 26mm) socket and a 1/2inch ratchet (i recommend any ratchet with 10* on it). As long as you break it loose it will go the rest by hand. No reason to pull the intake manifold.
CChong
Jan 16, 2017 02:53 PM
