Engine removal question
Hi all, this is probably a stupid question, but I just wanted to know if it's possible to remove the engine (D15) from a 5th gen civic WITHOUT removing the transmission (5spd).
Thanks in advance!
......(Removing D15 from 93 Civic, replacing with D16y7 out of 00 Civic.....replacing D16y7 with B18C
Thanks in advance!
You sure can but its a little difficult cause of the clutch. Its just easier to remove the whole thing as a unit. And a lot less frustration. I am assuming its a manual right?
oh yeah....lol. Me and the old man did this swap a few months ago, and I forgot to follow up on this. I told him what you guys had said, and he thought he'd go ahead and try it anyway. Well, it was a bastard to get it out, but it came. Getting it back in was a different story. theres really not a lot of room to get the input shaft aligned into the flywheel. Turns out it was so goddamn hard to get properly mated we just pulled the axle out of the knuckle on the drivers side, and unbolted the mounts so it could be lowered to the floor where we mated them together and easily put them back in from underneath.
I did it when I swapped my car, so its not impossible, its just a matter of wiggling and positioning of the picker. It took me 10 minutes tops to actually remove it with the help of a good friend. Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ2 »</TD></TR><TR><TD CLASS="quote">I did it when I swapped my car, so its not impossible, its just a matter of wiggling and positioning of the picker. It took me 10 minutes tops to actually remove it with the help of a good friend. Good luck!</TD></TR></TABLE>
i prefer to be called honda mastermind
Jhonny Ricer
Jun 6, 2007 05:54 PM
95civiccoupe31
May 28, 2002 03:54 PM
