Noisy Valve train
Old Dec 29, 2007 | 05:37 PM
eg6madness's Avatar
Default Noisy Valve train
I installed Buddy club Spec 4 cams, Buddy Club P1 valve springs (dual springs) and cam gears. Since then when i drive the head sound super noisy, there is a annoying rattle that sounds like something is loose.
A friend told me to recheck my Valve lash, another told me that it is the inner valve springs.
Anyone else installed similar and had tones of noise?
Old Dec 30, 2007 | 03:53 AM
Syner-G-Racing LLC's Avatar
Default Re: Noisy Valve train (eg6madness)
check your lost motion assemblies...is it local to a certain area or does the hole head make noises? cause high lift cams and stiff valve springs are alot noiser than stock.
Old Dec 30, 2007 | 05:16 PM
eg6madness's Avatar
Default Re: Noisy Valve train (Syner-G-Racing LLC)
It seems like the entire head.... it sounds like a train on tracks.....
Is that normal..... it takes some getting used to but it bites
Old Dec 30, 2007 | 11:10 PM
wed3k's Avatar
i know for a fact that my buddies crower cams have a tighter valve lash clearance as opposed to stock.
.006-.008 as opposed to .009-.012
Old Dec 31, 2007 | 01:16 AM
Default Re: (wed3k)
as long as the valve spring you got accomodate the lift on the cams to avoid coil bind your good. it sounds like its just noisy. you could post up a video or sound clip and we could help more
b20hatchek
13
Mar 20, 2015 11:26 PM
State.of.Prime
Oct 17, 2010 01:43 PM
daidilus
25
Aug 18, 2006 08:21 AM
Home Wrecker
Aug 18, 2006 05:50 AM
scUba-stEve
Jan 14, 2005 03:55 PM
