obd I motor into obd II car
alright so i'm replacing my blown obd II ls motor w/ an obd I b18b1...i know that i will have to run my obd II injectors and change the lower crank gear.....other than that, anymore problems i'll run into?? oh yeah the ecu i'm running is a P06......please give me all info that you know of as i'm having to pick up this motor in the morning
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pmpm06 »</TD></TR><TR><TD CLASS="quote">alright so i'm replacing my blown obd II ls motor w/ an obd I b18b1...i know that i will have to run my obd II injectors and change the lower crank gear.....other than that, anymore problems i'll run into?? oh yeah the ecu i'm running is a P06......please give me all info that you know of as i'm having to pick up this motor in the morning</TD></TR></TABLE>
You'll have to use the OBD2 distributor, or mod the OBD1 distributor harness.
Use the OBD2 alternator or mod the plug.
the car was turbo when i first bought it. so i guess maybe the obd I ecu for the chip and tune?? but it was unfinished.....so go ahead and go with the stock ls ecu instead?? no conversion harness
jdtphotography
Mar 3, 2007 06:54 PM
