Swapping in a D15B VTEC into a 95 civic vx
Old Dec 28, 2007 | 11:22 AM
DeathSquad's Avatar
Default Swapping in a D15B VTEC into a 95 civic vx
I have a 95 civic vx and im planning to swap in a jdm d15b vtec. i was wondering if it is jux a plug n play swap? and if my vx ecu would work on the d15b vtec or should i get another ecu to get the most power i can out of it? and if my vx tranny is a good tranny to swap into the d15b or should i get another tranny? any comments would be very helpful.
Old Dec 28, 2007 | 11:49 AM
1988_96hb's Avatar
Default Re: Swapping in a D15B VTEC into a 95 civic vx (DeathSquad)
an ex tranny is supposed to be the best d series tranny and vx is the worst
Old Dec 28, 2007 | 12:04 PM
DeathSquad's Avatar
Default Re: Swapping in a D15B VTEC into a 95 civic vx (1988_96hb)
okay, thnx. but wut about the ecu?
Old Dec 28, 2007 | 12:09 PM
1988_96hb's Avatar
the stock p07 ecu could be chipped i think (not sure, never got one chipped), but you cant use it as is for vtec. most ppl that i know use chipped p28s.
Old Dec 28, 2007 | 12:18 PM
DeathSquad's Avatar
ok. and how about the block. i have heard ppl say that the jdm d15b vtec block is identical with the d15z1 jux that the head is different. is that true? if it is should i jux swap in a different head?
Old Dec 28, 2007 | 12:34 PM
B18bEG6ick's Avatar
The Vx is way different from the jdm d15b. The d15b and the d16z6 are almost identical. There are alot of versions of d15b's out there; ODB1, ODB2, and I think OBD0. There are d15b that are vtec-e (which is the hx and vx here in the states). Try doing a search here there are a lot of info here and also in gassaver.org.
Old Dec 28, 2007 | 12:42 PM
DeathSquad's Avatar
Default Re: Swapping in a D15B VTEC into a 95 civic vx (B18bEG6ick)
o
Old Dec 28, 2007 | 12:49 PM
B18bEG6ick's Avatar
http://asia.vtec.net/article/d15b/
Here explains what are the d15b's, but search around you'll find out which ones which. Good luck with the swap. Also if you still have the VX motor let me know.
Old Dec 28, 2007 | 01:35 PM
1988_96hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEG6ick &raquo;</TD></TR><TR><TD CLASS="quote"> There are d15b that are vtec-e (which is the hx and vx here in the states)..</TD></TR></TABLE>
never heard that b4
hx=d16y5
vx=d15z1
jdmhonda25
Jan 3, 2014 09:53 AM
rountreesj
40
May 24, 2013 12:40 PM
kin413
18
Jun 26, 2007 09:35 AM
joepark2001
17
Mar 4, 2004 04:53 AM
Convoy
Nov 15, 2003 03:09 PM
