Help with valve cover lettering
Old Dec 27, 2007 | 01:58 AM
Ak_ef9's Avatar
Default Help with valve cover lettering
I want to grind down the old lettering and put up my own and then powder coat it. What could I use for a raised lettering that could withstand the heat and vibrations?
Old Dec 27, 2007 | 12:02 PM
Ak_ef9's Avatar
Default Re: Help with valve cover lettering (Ak_ef9)
Anything?
Old Dec 27, 2007 | 12:11 PM
SuzukaBlueAP2's Avatar
I was thinking you could maybe build it up with that quiksteel epoxy putty. it says it is good for temps up to 500 degrees F. I don't know just how hot the valve cover itself gets.
Old Dec 27, 2007 | 04:26 PM
zuum's Avatar
theres some stuff called alumilite (sp?) its a low temp brazing/welding rod you can use with a propane torch but better with map torch, after you have the letters roughed in you can just shape with some small files or something...
Old Dec 28, 2007 | 01:47 AM
Ak_ef9's Avatar
Default Re: Help with valve cover lettering (zuum)
Any other ideas?
Old Dec 29, 2007 | 03:03 AM
Ak_ef9's Avatar
Bump for more ideas
Old Dec 29, 2007 | 03:26 PM
Acidcrakker's Avatar
Shot in the dark, mabey use JB weld to do raised lettering. Youd have to make stensiled designes to create the dimensions on that.
Old Dec 30, 2007 | 08:19 PM
snowseeker's Avatar
Default Re: Help with valve cover lettering (Acidcrakker)
lead and a torch.
Old Dec 31, 2007 | 05:39 PM
Ak_ef9's Avatar
Default Re: Help with valve cover lettering (snowseeker)
No other ideas? Maybe lead and a torch and I can shape it?
Old Dec 31, 2007 | 07:24 PM
snowseeker's Avatar
yes, just about anything your going to do is going to need shaping.
Old Jan 1, 2008 | 08:08 AM
VeeL_B20's Avatar
Maybe this might give you some ideas!!! You could do something like this:
1. Get a good board (wood)
2. Cut letterings or designs on it
3. Clamp board on valve cover
4. Fill it in with some aluminum molding
Maybe use the stuff like this in this HOME MADE BLOCK GUARD:
http://www.hondatech.pl/printv...b71b8
You would have to get this stuff heat treated, but you get the idea.
Old Jan 5, 2008 | 03:33 AM
Ak_ef9's Avatar
Anybody else?
Old Jan 5, 2008 | 10:29 AM
GraphiteAccord's Avatar
I would weld alu plate to the Valve cover, and then use a vertical mill to cut the material out around the lettering.
Old Jan 5, 2008 | 10:48 AM
TeamNextGenChris's Avatar
Default Re: Help with valve cover lettering (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">I would weld alu plate to the Valve cover, and then use a vertical mill to cut the material out around the lettering.</TD></TR></TABLE>
that's similar to what i was thinking.have a CNC'd plate with whatever letterign you want,then tack it to the valve cover before powdercoating.i can't see anything handmade looking good.
Chris
Old Jan 5, 2008 | 12:54 PM
xzodiackillerx's Avatar
get the letters cut out of aluminum and TIG them to the cover....
Old Jan 5, 2008 | 02:32 PM
hybrid2007's Avatar
Default Re: Help with valve cover lettering (xzodiackillerx)
Depending on the size, a tig bead all the way around may not look that great. You could use a high temp epoxy or even drill holes through your valve cover underneath where the lettering would come and then plug weld the lettering on?
Taimaishui14
Oct 24, 2006 05:19 AM
turbotime
Nov 7, 2005 07:31 PM
vtec.dc2
May 6, 2005 01:40 AM
RedTegLS
Jan 23, 2004 09:34 AM
devonic
Aug 25, 2003 10:10 AM
