Sanding Valve Cover?
Is there any kind of bit i can buy for my drill that i can use to sand down the HONDA on my valve cover? I wanna go to home depot today after work and pick up some supplies to do this.
Re: Sanding Valve Cover? (devonic)
It is going to take quiote a bit of sanding to do it! And I mean a lot. Get a decent air powered grinder and grind away. I would suggest taking it to a maching shop. They can level it off and cut the letters to nearly eliminate them all together
Solbros Owns Me
Re: (devonic)
you can get attatchments for your drill to use a grinding disc or a sanding disc.
If you were good and careful, you could use some 40 grit paper on the disc to flatten out the raised letters, and use some higher grit to clean it up
nwdave
06-18-2003 03:30 PM
