eld code error
Old Dec 26, 2007 | 12:46 PM
ek98's Avatar
Default eld code error
having code 20,eld what do i do?
Old Dec 26, 2007 | 12:52 PM
Eran's Avatar
HT White Ops
Remove your under-hood fuse box, remove the plug from the bottom, and clean the connections on the harness and the plug.
If that doesn't fix it, try getting a new fuse box.
Old Dec 27, 2007 | 04:23 PM
ek98's Avatar
Default Re: (Eran)
thanks man
Old Jan 5, 2008 | 11:08 AM
redsohc101's Avatar
Default Re: (ek98)
The MIL is on w/ a DTC of P1298(electrical load dector) P0135Primary Heated Oxygen sensor) etc...
Probable cause:
The engine wire harness is rubbing on the intake manifold bracket.
Correction Action:
Repair the damaged wires, and protect the harness w/ corrugated tubing.
Applies to:
1996-99 Civic 4door,2door, and 3door
Honda Operation number 737001
Old Jan 14, 2008 | 09:42 AM
DrewMD's Avatar
Davis Photography
Would Honda cover this even though the car is beyond the warranty?
ntegrar
Aug 6, 2012 01:09 PM
vsmhatched
15
Jul 6, 2009 03:00 PM
DxBurnoutKing
May 19, 2005 01:12 PM
dingusjt
Nov 7, 2003 07:45 AM
