eld code error
Remove your under-hood fuse box, remove the plug from the bottom, and clean the connections on the harness and the plug.
If that doesn't fix it, try getting a new fuse box.
The MIL is on w/ a DTC of P1298(electrical load dector) P0135Primary Heated Oxygen sensor) etc...
Probable cause:
The engine wire harness is rubbing on the intake manifold bracket.
Correction Action:
Repair the damaged wires, and protect the harness w/ corrugated tubing.
Applies to:
1996-99 Civic 4door,2door, and 3door
Honda Operation number 737001
Probable cause:
Correction Action:
Applies to:
DxBurnoutKing
May 19, 2005 01:12 PM
dingusjt
Nov 7, 2003 07:45 AM
