GSR Longblock+LS crank/rods+P30 pistons(.25)=okay?
Old Dec 26, 2007 | 07:15 AM
00b18b's Avatar
Default GSR Longblock+LS crank/rods+P30 pistons(.25)=okay?
Im in the process of rebuilding a gsr that has rod knock. I'm gonna replace the rotating assembly with the LS to gain some torque and compression. I'm not sure nor ever done this so will the above setup work? Is the piston gonna be out the out the hole and touch the quench area?ill be using a oem 3 layer headgasket
Old Dec 26, 2007 | 07:21 AM
mx621's Avatar
Default Re: GSR Longblock+LS crank/rods+P30 pistons(.25)=okay? (00b18b)
it will work, but you will have to remove and cap off the oil squirters. they wont clear the crank. the deck hight of a gsr and ls block are the same so it will be fine.
Old Dec 26, 2007 | 07:42 AM
00b18b's Avatar
do u think ill have issues with the block girdle also?
Old Dec 26, 2007 | 11:38 AM
killerpenguin21's Avatar
Default Re: (00b18b)
nope, i run a gsr girdle and mains in my ls/vtec.
Old Dec 31, 2007 | 06:53 PM
bjones's Avatar
Default Re: (killerpenguin21)
bout wat compression ratio you lookin at with that setup?
Old Dec 31, 2007 | 08:39 PM
00b18b's Avatar
Default Re: (bjones)
roughly 11.8
03EM2guy
19
Mar 28, 2011 06:00 AM
EGkid
Jul 24, 2006 08:42 PM
black-hatch
Mar 13, 2003 08:54 PM
5 Skware
Feb 6, 2003 12:49 PM
hybrid901
Nov 11, 2002 12:34 PM
