motor fan and ac fan don't work
Old Dec 25, 2007 | 08:08 AM
mrlover's Avatar
Default motor fan and ac fan don't work
my car is 98 ls and both ac and motor fans dont' work. i already check all the fuses but still. can someone help please
Old Dec 25, 2007 | 10:29 AM
ooopseyesharted's Avatar
Default Re: motor fan and ac fan don't work (mrlover)
try the blower motor resistor or the fan switch itself. The resistor is bad in my car and only the #3 and 4 speeds work.
Old Dec 25, 2007 | 10:40 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: motor fan and ac fan don't work (ooopseyesharted)
im kinda confused, you mean the heat fan and the cooling fans for the motor dont work?
or just the heat and a/c fan?? If this is so they do what the other guy said those resistors are junk i had that problem in my rex andin my prelude
Old Dec 25, 2007 | 11:07 AM
Default Re: motor fan and ac fan don't work (stocker2shocker91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 &raquo;</TD></TR><TR><TD CLASS="quote">im kinda confused, you mean the heat fan and the cooling fans for the motor dont work?
or just the heat and a/c fan?? If this is so they do what the other guy said those resistors are junk i had that problem in my rex andin my prelude </TD></TR></TABLE>
They are a common problem on most hondas. You can get that part from the dealer ($60) or a local part store (35 at advance). Pop your glove bx open and your will see the blower motor. The wires to that motor go to the resistor
Old Dec 25, 2007 | 11:23 AM
dcRay's Avatar
Are you having a overheating problem? Those fan are electronically controlled by various sensors. They do not come on just because the engine is running.
Old Dec 25, 2007 | 11:26 AM
Default Re: motor fan and ac fan don't work (dcRay)
i think he means the heater/ac fan inside the car.
Old Dec 25, 2007 | 01:20 PM
mrlover's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooopseyesharted &raquo;</TD></TR><TR><TD CLASS="quote">i think he means the heater/ac fan inside the car.</TD></TR></TABLE>
no, i am talking about those 2 big fans attach to the radiator
Old Dec 26, 2007 | 12:43 PM
oh ****....sory
Old Dec 29, 2007 | 03:33 PM
mrlover's Avatar
Old Dec 29, 2007 | 05:51 PM
tsdneil's Avatar
also check your colant temp. sensors and your thermostat. if its not reading above operating temperature then the fans wont turn on.
Old Dec 29, 2007 | 06:00 PM
mrlover's Avatar
Default Re: (tsdneil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsdneil &raquo;</TD></TR><TR><TD CLASS="quote">also check your colant temp. sensors and your thermostat. if its not reading above operating temperature then the fans wont turn on. </TD></TR></TABLE>
both fans should work once you turn on AC regardless of temperture hot or not.
Old Dec 29, 2007 | 06:15 PM
doughboixx's Avatar
check your fan switch and thermostat....i had the same problem and i changed both now it works great...goodluck...
Old Dec 29, 2007 | 08:50 PM
mrlover's Avatar
Default Re: (doughboixx)
fan switch? where is it at?
Old Dec 31, 2007 | 07:33 PM
lakerschamp2000's Avatar
come on hondatecher....
stinkbox
10
Sep 15, 2011 02:02 PM
lordfuzzz
Jan 13, 2010 01:43 AM
busted90accord
Apr 3, 2008 08:12 AM
976
Sep 9, 2001 08:22 PM
