No Instuments or clock. Advanced electronic issue
Old Dec 24, 2007 | 07:56 PM
BOMBCRU's Avatar
Default No Instuments or clock. Advanced electronic issue
Replace a bad switch in my 94 ls. When pulling the old switch it touched the column and shocked it.... New switch, fuel pump didnt turn one. Changed back to old switch, car starts...
Problem is: Gauge lights work, No clock,No speedo, No fuel, No rpm, No coolant temp, No tripometer....
All fuses under hood and under dash are good.
Wiring seems to be good, no smoking, no burnt wires...Was a zap
Ecu is fine.
Only Thing i can think of is maybe the main relay fried....But the car still runs..
Any idea's?????????
Old Dec 24, 2007 | 08:06 PM
Blahblah718293's Avatar
Default Re: No Instuments or clock. Advanced electronic issue (BOMBCRU)
or a shorted wire, time to rip that stuff apart.
were you replacing electronic parts with the battery still attached?
Old Dec 24, 2007 | 08:14 PM
BOMBCRU's Avatar
Default Re: No Instuments or clock. Advanced electronic issue (Blahblah718293)
Ya, i thought i pulled the + but i didn't
I don't see any damaged wires. That would be like 5 shorted wires for all those to be bad id think?!?!?!?
Old Dec 25, 2007 | 07:23 AM
dcRay's Avatar
Check your big fuses under the hood. Sounds like you shorted the Ignition II circuit. Or the new switch you are puting on is not turing to Ignition II.
t3to4e
May 17, 2010 03:33 PM
JDM_d15b_eg8
Dec 26, 2006 05:17 AM
92integraVTECgsr
Audio / Security / Video
Oct 10, 2005 09:14 PM
Ham'ed Hatch
Jul 12, 2002 11:03 AM
5 watt
Jul 5, 2002 12:07 PM
