Throttle positioning sensor (Cel 7)
Old Dec 24, 2007 | 12:14 AM
Paul-eg's Avatar
Default Throttle positioning sensor (Cel 7)
Hey,
I have been getting a CEL7 which is TPS.... on my jdm b18c eg I replaced the TPS with one I got off my friend from a D series. I installed it got it all dialed it to oem specs. I didnt use a gasket because I couldent find one but i have heard you dont need them. One week later im getting the same code. I checked all the wiring going to the ECU all looks good. The CEL is not always on. On some trips it comes on... on others it doesnt. You thing I just got a shotty TPS? What could I try? Should I just buck up and get a new tps from some b series at honda?
Thanks
Paul
Old Dec 24, 2007 | 10:00 AM
Paul-eg's Avatar
Default Re: Throttle positioning sensor (Paul-eg)
ttt
Old Dec 24, 2007 | 10:08 PM
SEATownboi08's Avatar
Try different Dizzy if its a jdm swap then id def try a USDM dizzy
Old Dec 24, 2007 | 10:24 PM
93egSLEEPER's Avatar
do u have a temp sensor in the intake pipe? that threw the same code on my JDM B16 swap.
Old Dec 25, 2007 | 01:31 AM
Paul-eg's Avatar
Default Re: Throttle positioning sensor (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">do u have a temp sensor in the intake pipe? that threw the same code on my JDM B16 swap.</TD></TR></TABLE>
pretty sure i dont have a tem sensor in the intake pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul-eg &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
just wondering what would a usdm dizzy do it never use to throw that code before till the last couple weeks
Frany
Sep 2, 2015 07:40 AM
green 3gg
Sep 16, 2008 05:12 AM
Paul-eg
Jan 4, 2008 07:52 AM
ejoner
Oct 23, 2007 08:03 PM
integra95gsr
Jun 22, 2006 09:36 PM
