d16y8 to d16y7 swap ek
Old Dec 23, 2007 | 03:17 PM
b0nez's Avatar
Default d16y8 to d16y7 swap ek
Threw a rod on the y8 and I have the y7 laying around. Will this harness and ecu work from the y8? onto the y7
or do i have to move some pins around
Old Dec 23, 2007 | 03:31 PM
ifIexplode's Avatar
it will throw codes for VTEC
The fuel maps are different so it may throw a code for that too.
And maybe a knock sensor.
But the harness will work no problem. are both motors the same OBD2?
Old Dec 23, 2007 | 03:34 PM
hplssone's Avatar
Default Re: (ifIexplode)
you will need the y7 computer. If the harness is from an automatic ex, it will work. You will have a couple extra plugs for the knock sensor and the vtec. If it is from a manual, you will need to change the pins for the iacv and get a pig tail from either a dx or an automatic ex, and add a third wire. I would suggest using the intake manifold from the y8. This will ensure the wire harness will reach the sensors. If it is from a manual car you will have to use the y7 throttle body with it and leave the y8 iacv attached to the intake manifold to plug the holes.
knightsef-eg
Apr 25, 2010 07:35 PM
greensi00
34
Dec 20, 2009 02:01 PM
dizzyek
Jun 25, 2006 03:01 PM
g2turbo
Jul 2, 2003 11:58 PM
spikeddrummer
May 20, 2003 11:32 AM
