Installing Spark Plug Seals
Old Dec 22, 2007 | 06:42 PM
EK_B's Avatar
Default Installing Spark Plug Seals
So do I just take off the valve cover and pull the old ones off and just plug in the new ones? Easy as that?
Or is there a certain way to install them?
Any other recommendations? Thanks.
Old Dec 22, 2007 | 06:43 PM
z6hatchboy's Avatar
Its as easy as that
Old Dec 22, 2007 | 06:58 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Make sure all 4 stick to the valve cover, when putting it back on the head.
Old Dec 22, 2007 | 07:03 PM
z6hatchboy's Avatar
^x2!
Old Dec 22, 2007 | 07:33 PM
crazyguy's Avatar
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">^x2!</TD></TR></TABLE>
X3
Old Dec 22, 2007 | 10:33 PM
EK_B's Avatar
So do I have to put anything on it to bond them to the valve cover?
Old Dec 22, 2007 | 10:36 PM
yoffer's Avatar
Banned
You shouldnt. Just wipe inside where the seal goes after you take out the old ones and set the new ones in.
Old Dec 22, 2007 | 10:37 PM
Eran's Avatar
HT White Ops
The easiest way I've found is to remove the old ones with needle nose pliers by twisting (till it curls) and then pull.
When installing the new ones, I use urea grease around the edges, and pound them into place with a rubber mallet.
Old Dec 23, 2007 | 12:00 PM
Pound them into place? Your not useing over size gasket are you? J/K man.
vladvv
Honda CR-V & Element
Sep 20, 2012 08:20 PM
brucepick
Jan 22, 2011 08:51 PM
Ritchie
12
Dec 21, 2006 07:29 PM
themorphious
Jun 3, 2006 12:14 PM
integlspwr01
12
Oct 13, 2003 11:16 PM
