thermostat location...mixed results
Old Dec 21, 2007 | 09:15 PM
devilpuppy's Avatar
Default thermostat location...mixed results
okay, i've done many searches on many sites... i've even called a local dealer...
where is the thermostat located on the 1990 accord EXR (us based EX)?
many results say to follow the lower rad hose and it will lead you to the houseing right infront of the throttle body...
other search results are saying to follow the upper rad hose...
i called my dealer...and he said upper...but he sounded hesitant in his voice.
Old Dec 22, 2007 | 03:45 AM
GhostAccord's Avatar
Default Re: thermostat location...mixed results (devilpuppy)
I'm not sure what hose to fallow. Your thermostat is found in the TH housing attached to the intake manifold. That would be the one that is located near the throttle body not on the front of the block.
Old Dec 22, 2007 | 06:30 AM
b18cx's Avatar
follow the lower hose. Fact.
Just got through replacing the t-stat on my 91 Accord wagon.
Old Dec 22, 2007 | 07:15 AM
GrantD's Avatar
my 94 lx coupe was in the back, my buddies 89 was as well. eitherway its a 50/50 shot with about 10 minutes to lose and a small amount of coolant. So I'd just pick one and go with it.
Old Dec 22, 2007 | 08:27 AM
hondaccord's Avatar
Default Re: (GrantD)
fallow the bottom radiator hose there it is.
Old Dec 23, 2007 | 07:30 AM
arielb1's Avatar
Default Re: (hondaccord)
keep in mind, when you replace the thermostat...I might have to go in a certain way. Usually there is a little tab on the ring of the thermostat. This tab should be in 12:00 position. Then when installing the gasket, watch the tab. In other words, research how the thermostat goes in.
Old Dec 23, 2007 | 03:58 PM
devilpuppy's Avatar
DONE!
it was following the lower hose...
the positioning....i just matched up the previous dots on teh gasket and popped it back in
Old Dec 23, 2007 | 08:46 PM
hondaccord's Avatar
Default Re: (devilpuppy)
yep easy ain't it lol
MugenTGZ
May 22, 2013 01:57 AM
jtac616
Oct 10, 2012 04:25 AM
Wyatt87
Aug 15, 2012 12:48 PM
mullenium
Oct 12, 2008 03:08 PM
